Inductive sensors as endstop 24V
For NPN NO (normally open) the easiest way is to add a diode in series (beware of the polarity).
thanks alot....looks quite easy.
What voltage are you inductive sensors rated for? I've found that 6-36 and 10-30v inductive sensors work fine running on 5v:
Proof that they work:
https://youtu.be/Bov87qlX0Gs
Proof that the readings are reliably repeatable:
https://youtu.be/_-fAMAnn3_sSo, if you are using this type of sensor, you don't need to worry about it, just plug them into the 5v sensor port, and job's a good'un.
me again
i tried it with the diodes now.....
unfortunally non of the diodes worked properly.
non dropped the voltage below 0 always around 1.2 V which the duet doesnt measure as triggered.
by accident i used a diode which i measured in non triggered state 22.6 V by mistake i connected it to the board and it works.... nothing burned.
does that mean the duet has no problem with 22.6 v on that PIN?i am a bit confused
You need a Schottky diode (for boards up to rev 1.3)
From the documentation:NPN output normally-open inductive or capacitive sensor
Duet 2 Maestro, or revision 1.04 or later of Duet WiFi or Duet Ethernet: you can connect the output of the sensor directly to the Z-probe IN pin.Other Duets: Connect the output wire of the sensor to the cathode of a diode, and the anode of the diode to the Z probe IN pin. The diode should preferably be a small-signal Schottky diode such as BAT43 or BAT85, but a small signal silicon diode such as 1N4148 works for some people.
All Duets: Connect the sensor ground wire to a ground pin on the Duet, and the sensor's + power wire to a suitable voltage (typically to VIN because these sensors usually need between 6 and 30V power).
Select mode 5 (P5) in the M558 command, also include parameter I1 in the M558 command.
@whosrdaddy said in Inductive sensors as endstop 24V:
That only mentions the Z-Probe pin and not the endstop inputs, I would wait for clarification from Tony or David before hooking the sensor to an endstop input without the diode.
Yeah missed that fact.
The endstop inputs are 3.3V and directly connected to the CPU, I believe the diode trick will still work but I don't know it will be safe... -
I do use 24v inductive sensors on my V1.04 board with diodes without issue.
@tjb1 great which diode do u use ?
@orthocube said in Inductive sensors as endstop 24V:
I bought both the BAT43 and BAT85 as described here but I don't recall which one I actually used on my setup, I think I used the BAT43 as I remember the blue color but either one should work.
The endstop inputs are 3.3V and directly connected to the CPU, I believe the diode trick will still work but I don't know it will be safe...Yes the same diode connection can be used with endstop inputs as with the Z probe.
