Could do with some help with sensorless homing on a CoreXY
OK, I've tried temporarily setting CoreXY mode but unfortunately I still don't seem to be getting any detection of motor stall. I do now get an error message saying that homing has failed which is a step in the right direction. I also tried moving X and Y simultaneously but when X reaches the physical stop both motors simply vibrate alarmingly until the remainder of the move completes.
I've tried reducing acceleration and increasing speed. Current homex.g now looks like this:
M669 K1; coreXY mode - reason temporary firmware bug
G91; relative
M584 X6 Y9; temporarily map dynamic load gantry steppers to X and Y
M906 X200 Y200; reduce motor currents
M201 X400 Y400; reduce accelerations
M915 P6:9 S0 R0; configure stall detection
M574 X1 Y1 S3; configure end stop switch for stall detection
G1 X-400 F4000; do a long slow move to x min - tried doing G1 X-400 Y-400 F400 but no difference
M574 X1 S1; configure end stop switch back to where it was
M669 K8 ; put kinematics back to CoreXYUV
M201 X1000 Y1000 ; put accelerations back to 1000M122 reports SG values for D6 and D9 but they are highly variable. After the last homeX I have SG min/max of 0/52 for drive 6 and 0/46 for drive 9.
If it helps, motor specs as follows:
Voltage (VOC) 2.80
Amps/Phase (2.00
Resistance/Phase (Ohms @25degC) 1.4+_ 10%
Inductance/Phase(mH@1KHz) 3.00+_20%
Holding Torque (Nm) 0.59
Step angle 1.8
Rotor Inertia (g-cm) 82.00 -
From the datasheet:
Due to the dependency of the stallGuard2 value SG from motor-specific characteristics and application specific demands on load and velocity the easiest way to tune the stallGuard2 threshold SGT for a specific motor type and operating conditions is interactive tuning in the actual application.
The procedure is:- Operate the motor at a reasonable velocity for your application and monitor SG.
- Apply slowly increasing mechanical load to the motor. If the motor stalls before SG reaches zero, decrease SGT. If SG reaches zero before the motor stalls, increase SGT. A good SGT starting value is zero. SGT is signed, so it can have negative or positive values.
- The optimum setting is reached when SG is between 0 and 400 at increasing load shortly before the motor stalls, and SG increases by 100 or more without load. SGT in most cases can be tuned together with the motion velocity in a way that SG goes to zero when the motor stalls and the stall output SG_TST is asserted. This indicates that a step has been lost.
I'm wondering whether the back emf of those motors is too low at the very low motor current you are using, but I understand why you don't want to use a higher current.
HTH David
@dc42 said in Could do with some help with sensorless homing on a CoreXY:
I'm wondering whether the back emf of those motors is too low at the very low motor current you are using, but I understand why you don't want to use a higher current.HTH David
Hmm. Well I think there is a real risk of some physical damage happening if I try and increase the current.
Maybe sensor less homing isn't an option with these motors and I have to come up with a plan B.
Any ideas? I do have a couple of spare estop connectors on the Duex5 and I could fit a couple of switches easy enough.
As a temporary solution, I've made use of M291 in my homing files to prompt me to move the load cancelling gantry to the appropriate position. Along with reducing motor currents, this will hopefully be enough to prevent anything nasty happening - at least until I can come up with a better plan.
You could define the two additional motors as axes A and B while homing them, allowing you to use endstop inputs 5 and 6 aka E2 and E3 assuming there is no W axis.
Thanks. I'll give that a go when I get chance. E2 and E3 are currently used for axes maxima and another switch to trigger an emergency stop, but I can move them to E4 and E5 easily enough.
@dc42 OK, so I've hooked up a couple of switches but still not having a great deal of success. I get movement in the X direction for axis A but no movement in the Y direction for axis B. Then after "attempting" to home A and B, my homeall.g file then homes XYU and V as it has always done, but after these have been homed, no movement in the X direction is possible for any of the gantries. Homeall. g normally moves to the centre of the bed for Z probing but after doing XYU and V., it only moves in the Y direction. However, movement in Y works fine for all 3 gantries.
It's likely that I have missed or configured something incorrectly but after a few hours, I still can't find my mistake.
My annotated homeall.g is as follows:
; homeall.g
; called to home all axes
; Use This for Dynamic Load Gantry - mapping is different*; start by warming the hot end so that any oozed filamnt is molten
TO; select a tool - any one will do
M104 S140; heat to 140 but don't wait;********** COMMANDS FROM HERE ADDED FOR UPPERMOST (3RD) GANTRY ********
M584 X0:3:6 Y1:4:9 Z2 U10 V11 E5:7:8 P3; make sure mapping is as per config.g to start with
M906 X400 U400 Y400 V400 Z1200 ; reduce motor currents
M584 A6 B9 P7; create A and B axes for upper gantry
M574 A1 B1 S1 ; create end stops E2 and E3 for the new A and B axis
M350 A16 B16 ; configure microstepping for A and B
M92 A80 B80 ; configure steps per mm for A and B
M566 A600 B600; inst speed change
M203 A50000 B50000; max speed
M201 A1000 B1000; accel
M208 A0 B0 S1; axes minima
M208 A380 B380 S0 axes maximaG91 ; set to use relative coordinates
G1 A-380 B-380 F4800 S1 ; move fairly quickly until one of other end stop switches triggers
G1 A-380 S1 ; course home A
G1 A10 F600 ; move back a few mm slowly
G1 A-380 F360 S1 ; fine home A
G1 B-380 F4800 S1; course home B
G1 B10 F600 ; move back a few mm
G1 B-380 F360 S1 ; fine home B
; *****DURING THE ABOVE, THERE IS "A" axis MOVEMENT IN THE X DIRECTION
; *****BUT NO "B" axis MOVEMENT IN THE Y DIRECTION
; ***** AND THE A(X) AXIS SEEMS TO BE IS LOOKING FOR THE B(Y) ENDSTOP; END OF ADDITIONAL COMMANDS*
M584 X0 U3 Y1 V4 P5; temporarily map drives to U and V axes - have to map both axes even thought only U is being used due to both motors being employed per axis
G1 Z5 F600 ; move bed down 5 mm
G1 X-380 U-380 Y-380 V-380 F4800 S1; move all 4 axes fairly quickly until one or other triggers a switch
G1 X-380 U-380 F4800 S1; now move just X and U fairly quickly left until one or other triggers a switch
G1 X-380 S1; course home X
G1 U-380 S1; course home UG1 X10 U10 F600 ; Go back a few mm
G1 X-380 U-380 F360 S1; Move slowly to X and U axis endstops once more and stop when one triggers
G1 X-380 F360 S1 ; fine home X
G1 U-380 F360 S1 ; fine home UG1 Y-380 V-380 F4800 S1; now move Y and V fairly quickly left until one or other triggers a switch
G1 Y-380 S1; course home Y
G1 V-380 S1; course home VG1 Y10 V10 F600; Go back a few mm
G1 Y-380 V-380 F360 S1; Move slowly to Y and V axis endstops once more and stop when one triggers
G1 Y-380 F360 S1 ; fine home Y
G1 V-380 F360 S1 ; fine home VM584 X0:3:6 Y1:4:9 Z2 U10 V11 E5:7:8 P7; add dynamic gantry to XY ; map all 3 gantries to X and Y
G90; set to absolute coordinates
; ******* FROM THIS POINT ON, NO MOVEMENT IN THE X DIRECTION IS POSSIBLE
; ******* JUST NOTHING HAPPENS WHEN ANY X MOVE IS ASKED FOR
; ******* THIS APPLIES TO ALL 3 GANTRIES
; ******* BUT Y DIRECTIONS MOVES WORK FINE FOR ALL 3 GANTRIES AS DOES Z
;******** THIS BEHAVIOUR PERSIST AFTER HOMING AND THE MACHINE HAS TO BE RESET.G1 X180 Y180 F12000; move all 3 gantries to more or less the centre of the bed
; **** AS STATED ABOVE, THE X DIRECTION COORDINATE NO LONGER HAPPENS
M109 S140 ; continue heating bed to 140 but this time wait
G30
G91 ;relative
G1 Z5 F300
G90 ; back to absoluteM906 X1800 U1800 Y1800 V1800 Z1800 ; set motor currents back to defaults
M104 S0; set hot end temp back to zero
Above post deleted - me being stupid.
Edit. Post restored, I'm still probably stupid but not for the reasons I thought.
Also tried sensor less homing as above with motor currents set to 500mA but still no stall detected. At a bit of a loss as to what to try next.
This is just a shot in the dark but it feels odd to me that
M584 X0:3:6 Y1:4:9 Z2 U10 V11 E5:7:8 P3; make sure mapping is as per config.g to start with [...] M584 A6 B9 P7; create A and B axes for upper gantry M574 A1 B1 S1 ; create end stops E2 and E3 for the new A and B axis
this would work as intended. I mean the part where you first do the axes definition and then reassign drives to other axes and assume that E2 and E3 match to these axes. I looked into the source code and even though I did not understand everything I found I think you need to define the new axes in the right order in one command. Something like the following might be more correct:
M584 X0:3 Y1:4 A6 B9 Z2 U10 V11 E5:7:8 P3
I think it needs to be done like this because parsing
M584
does not really care about the letters being in strict XYZUVWABC order anymore but the order they are given is more or less responsible for the endstop-mapping. So in your current setup the endstops would be mapped toU
andV
.At least something to try.
@wilriker Thanks for that. It makes sense so I'll give it a try.
OK, so I've tried @wilriker's suggestion. Essentially, I've moved the creation of the A and B axes to config.g. So I have in config-g:
M584 X0:3 Y1:4 Z2 A6 B9 U10 V11 E5:7:8 P3;
followed by:
M574 Z0 S0 ; Define active low and unused microswitches
M574 X1 Y1 S1 ; Define active high microswitches
M574 U1 V1 S1 ; active high switches for when temporary U and V axes are employed during homing the upper XY
M574 A1 B1 S1;Then I've set all the other axis related parameters for all 7 axes (M350, M92, M566, M203. M201 etc).
After which I remap drives thus:
M584 X0:3:6 Y1:4:9 Z2 U10 V11 E5:7:8 P3; Remap A and B to X and YThen I've simplified the start of homeall.g so that it starts with this:
M584 A6 B9 P7 ; RE-Map A and B
;G1 A-380 F4800 S1 ; course home X
;G1 A10 F600 ; move back a few mm slowly
;G1 A-380 F360 S1 ; fine home A
This has helped in as much as at the end of homing, all axes now move in both the X and Y directions. However, homing A and B does not work and I've figured out the reason why. Basically I get diagonal movement when asking for pure X or pure Y moves. This was masked in my earlier attempts at homing A and B because I started with a diagonal move in any case. I've now taken that out.
So it seems that when I create A and B in config.g, they are created as Cartesian axes and only move one motor, rather than CoreXY which requires both motors to be moved. Also, A (X) still seems to be looking at B(Y) end stop - actually I think (but can't be sure) that both axes look at the same end stop - I'll check that.
Late thought. I've just noticed that I create U and V before A and B so that might be the end stop issue. I'll swap and report back.....
Latest update. Creating axis in the correct order seems to have fixed the end stop recognition issue. So this in config.g works
M584 X0:3 Y1:4 Z2 U10 V11 A6 B9 E5:7:8 P3;
All I'm left with now is that the A and B axes move diagonally using a single motor, rather than in X and Y using both motors. i.e Cartesian rather than CoreXY kinematics. So close....
@deckingman What happens if you swap
by
A
andB
defined beforeU
andV
)? Will this make the extruder gantry act as Cartesian and have the counter-weight gantry move correctly? -
@wilriker That's what had at first - see post one before my last timed at 10:41. I still had the Cartesian axis movement (for A and B) but also, the endstop switches weren't being acted on correctly.
Edit. The extruder gantry (U and V) still acted correctly as CoreXY.
2nd Edit It's kind of coming back to this thread https://forum.duet3d.com/topic/6677/corexyuvwa
Do you think making the axes W and A rather than A and B would help? It used to be necessary to create them in that order but I believe that later firmware doesn't care. Just wondering if there is something in the firmware left over from how it used to be that shouldn't be there.....
@deckingman Honestly, I checked the source code again and I have no clue how an endstop is assigned to an axis at all. I found the code where the endstop is setup per axis but I have yet to find the place where it looks for a specific endstop for a given axis.
Anyway, while I am hunting this part down (and I have an idea where to look for) I have another question: I have something in the back of my mind, but not sure anymore. Do you switch at any point (after homing) to CoreXY mode? Also once you assigned all three steppers to X/Y do they move correctly i.e. A/B also act like CoreXY kinematics?
@wilriker An endstop code is in Movement\Kinematics\CoreBaseKinematics.cpp
If the drive is shared, in CoreXYKinematics.cpp the method DriveIsShared returns true, which is evaluated in the CoreBase file.
The OnHomingSwitchTriggered method is called from Movement\DDA.cpp line 1595 in the v2-dev branch. It is called when an endstop is hit.
@wilriker said in Could do with some help with sensorless homing on a CoreXY:
Thanks for taking the time Manuel.
I use M669 K8 near the very start of config.g, before anything related to drives or axes. This sets CoreXYUV mode. I don't use any other commands related to kinematics anywhere else.
Yes, when motors 0, 3 and 6 are assigned to X and motors 1, 4 and 9 are assigned to Y, all three gantries move correctly as a single CoreXY. This works both before and after homing.
(Actually the upper gantry moves in the opposite direction because the motor directions are reversed for 6 and 9 compared to the rest).
I think end stops are working properly now. It's just the motion for AB when it operates as a single gantry.
@joergs5 said in Could do with some help with sensorless homing on a CoreXY:
That's what I meant when I said I have an idea where to look for.
@deckingman Thanks for clarifying your kinematics used. As far as I can see on an earlier post you tried mapping the steppers for the load gantry already to drives X and Y temporarily. But you only tried this with the unsuccessful stallDetection as endstop. Could you try again with end stops but please map them to U/V axis instead of X/Y. If this works I have an idea of what the issue might be.
EDIT: And just for my curiosity: can you please tell me which motor is connected to which port and which endstop to which port? I cannot let this endstop-mapping issue go (even if it now works for you this totally confuses me how this is working at all and I miss the actual wiring info to make sense of it ).
Well mapping drive 6 (A) to U and drive 9 (B) to V at the start of the homing file kind of works in that the kinematics are correct - I do get pure X and pure Y moves. BUT, it ignores the end steps on the upper (AB) gantry. It uses the end stops on the UV gantry so never triggers (unless I manually trigger the UV end stop switches.
Drives are as follows:
These are on the Duet main board
Drive 0 is X
Drive 1 is Y
Drive 2 is Z
Drive 3 is U (usually mapped to X)
Drive 4 is V (usually mapped to Y)
These are on the Duex5
Drive 5 is the first extruder (E5)
Drive 6 is A (usually mapped to X)
Drive 7 is the second extruder (E7)
Drive 8 is the third extruder (E8)
Drive 9 is B (usually mapped to Y).End stops are normally closed switches connected as follows:
On the Duet main board
X is X,
Y is Y,
Z isn't used
U is E0
V is E1On the Duex5
A is E2
B is E3E4 and E5 are connected to additional switches which are used in conjunction with M584 to trigger emergency stops.
It'd be really handy if we could map end stops to axes but I seem to remember from the time when we were trying to get CoreXYUV homing that this wasn't possible. If I could do that, I wouldn't need to create additional axes. Just map drives and end stops to existing axes.
