layer heights in print status web interface
Running a print from S3d with two different layer heights.
The bottom part of the part was 0.2mm and so the web interface is displaying:
Layer Height 0.15mm/0.2mm (the first layer height was set to 75% in S3d slicer).
Now we're well into the top part of the part which has a layer height of 0.1mm but the web interface continues to display as before.
This is not a big deal but if had a choice (given limited screen space) would rather have the web interface display the CURRENT layer height.
Any views on this?
Which firmware version? I made a change to the layer detection in 2.02RC4 or RC5, I forget which.
fair enough
2.01(RTOS) (2018-07-26b2)
If you change something, it also shows the z-hop height as first layer height. Edit - not S3D, Slic3r PE (2.02 RC5)
