Mesh Grid - Result is not ok
Does your bed surface have a bit of a reflectiveness to it? Can you try probing your bed with a piece of plain white printer paper on it? I'm thinking maybe the IR probe isn't getting a good reading from your bed surface.
I have The buildtak Vertex
I will Test it tommorow
If its reflectiveness what i can use to probing?
You can try adding an A and S parameter to your M558 command to try and increase probing consistency.
M558 A10 S0.003
this will cause the probe to probe up to 10 times if the consistency of two consecutive probe results are within 0.003mm of each other.
Like this
M558 P1 H4 F120 T6000 A10 S0.003
@lui2004 Yes
Ok i i will test now
with white printer paper i got
Error: Z probe already triggered before probing move started
with M558 P1 H4 F120 T6000 A10 S0.003
i got
20.00,200.00,20.00,200.00,-1.00,40.00,40.00,5,5
0.003, 0.548, 0.559, 0.647, 0.682
0.476, 0.589, 0.143, 0.761, 0.788
0.573, 0.633, 1.234, 0.772, 0.788
0.636, 0.613, 0.753, 0.771, 0.841
0.603, 0.835, 0.740, 0.761, 0.978 -
@lui2004 said in Mesh Grid - Result is not ok:
Try increasing your dive height perhaps? I'm not super familiar with the behaviour of the IR probes.
I can't tell from the number grid if that's an improvement or not. Does the image look more consistent?
Is there any direct lighting around your machine? is your machine around any natural (outside) lighting? I have read that florescent lighting and possibly LED lighting can cause issues.
@wyvern Hi
no, no direct lighting to the machine.
only normal natural lighting and no LED or somthing else
hope everybody can help me to solve
Are the thick whites lines on the bed in your photo part of the bed, or part of a print? If they are part of the bed then it's possible that you may get a different trigger height when you probe over them, compared to probing over the dark grey areas.
The only types of lighting that affect the IR sensor are direct bright sunlight (no clouds in front of the sun), and bright tungsten halogen light. If the sensor detects too much of either, the LED will blink rapidly.
@dc42 https://i.ytimg.com/vi/YGnV8EXvhzs/maxresdefault.jpg
It part of the logo, when I saw this I was going to assume it was causing problems. OP's probe also looks like it is over the edge of the bed?
its hard to tell but it almost looks like the logo is clear or doesn't have black. that will trip up an ir sensor
Yes, the probe points will probably need to be adjusted so that the sensitive area of the IR sensor (roughly under the cylindrical black capacitor) are never off the edge of the bed or over the white areas of the logo.
Hi
Yes i found out The white areas are the problem.
I have tested with black matt paper the mesh is flat / green now.
How can i set new probe points only of The black bed for G29?
You have an example for me ?
Sorry my english is bad
The probing grid for G29 is defined by the M557 command. You would need to chose the X and Y spacings and the range to avoid the white logo.
Alternatively, if you can probe with a piece of black paper lying flat on the bed, do that. If the printer is mechanically stable, you shouldn't need to probe very often. For most prints you can load the height map produced by the last probing you did, by sending command G29 S1.
@dc42 i will test it to load the highmap and to print
I have order PrintBite in Black Matt hope this will work with your mini ir
Thanks
