After every power-off, I lose my Z zero.
@veti I'm using the thermistor that came with the Prometheus V2, a 100KOhm Semitec 104GT2 NTC thermistor according to the documentation. I haven't changed any thermistor values anywhere - should I have?
It could be that I'm mistaken and the issue isn't under-extrusion. The sides of the print don't look under-extruded now that I'm looking at the print with fresh eyes. It's just the top and the fact that infill isn't always connecting to the shells. Here are some pictures from a test print. I think the bottom issue is likely because I need to lower my zero a bit, but when I autocalibrate (with paper, no probe) the hotend has a decent grab on the paper. I mean I can still move it back and forth, but there's significant friction, so Idk.
Regarding the losing my zero after power-offs, doesn't autocalibrate save the settings once you finish the routine?
@deckingman I noticed that the Bondtech Mini isn't up anymore, too. I wonder if he discontinued it.
Can you post your config file?
What firmware are you running?
How fast are you printing that?
Have you tried printing something larger? The tiny calibration objects aren't the greatest indicators.
The steps per mm of your extruder is very low. I think you may benefit from running a higher microstepping value on the E axis.
The first layer definitely looks like it's a bit too far away from the bed. You can baby step down a bit and see if it improves.
@layerslayer said in After every power-off, I lose my Z zero.:
No it's there. But it's listed under "Upgrade kits" then "Wanahao" which is why I didn't see it under "Extruders" (where I would have expected it to be). Anyway, once I found it I see that the steps per mm are listed as 140 so your setting should be right (providing you are using 16x micro-stepping).
So before submitting this comment, I took a closer look at my slicer and realized I hadn't set it up properly. I had always used my laptop for slicing and printing, but this installation is on my desktop now that I can wirelessly send my G-code. Anyway, my nozzle was set to 0.5mm because that was the OEM hotend nozzle size and I had never changed it after installing a while back. That said, I still have a little underextrusion, but it's improved a lot.
@deckingman Oh you're right. I had only seen the bracket last I looked. But yeah that's it.
I suppose it's a little fast for the calibration part, but I've run pretty fast in the past without these issues. I'll reprint it right now with slower speeds and a fresh auto-calibration.
I'm running RepRap Firmware 2.02
I have printed something larger, although I didn't complete it (Had to leave and didn't want to leave my first run on the Duet while I was out of the house lol). The thing is that I used to get some really good results on this test piece with my Rambo. The Duet is clearly superior, but I'm missing something in my calibration or configuration.
The steps/mm was perfect on the Rambo and it's 1 step/mm above what is called for by Bondtech for this extruder.
And here's my config.g:
; generated by RepRapFirmware Configuration Tool v2 on Mon Mar 11 2019 18:54:24 GMT-0700 (Pacific Daylight Time); General preferences
M665 R132.65 L325 B132.65 H311 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them; Network
M550 P"Rostock Max" ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M92 X80.00 Y80.00 Z80.00 E141.00 ; Set steps per mm
M566 X900.00 Y900.00 Z900.00 E1100.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; Set accelerations (mm/s^2)
M906 X1200.00 Y1200.00 Z1200.00 E1200.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active low and disabled endstops; Z-Probe
M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
M557 R132.65 S20 ; Define mesh grid; Heaters
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S105 ; Set temperature limit for heater 0 to 105C
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S0.8 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
Try adding 'M350 E128' below you existing M350 and M92 entries. This will put the extruder on x128 microstepping. The duet will auto calculate the new steps per mm, so don't change those. See if that helps with extrusion.
Having the nozzle size set lower could definitely be a factor.
Your speeds looks reasonable.
Every time I turn my printer on, I have to run another auto-calibration (the old school paper way) because otherwise the prints begin a little over 15mm above the bed.
Have you solved this issue yet? If not then see the second post in this thread.
@dc42 If you mean the bit about saving the auto-calibration after running it, I haven't had a chance to try and figure that out yet. It always worked after the calibration so I assumed the values had already been saved, but I guess maybe not. I'll look into it when I get a chance tonight. Thanks!
there is a section about saving in the documentation about delta calibration.
https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer -
@veti Thanks, I was actually just browsing that page on my phone. Somehow I overlooked the part about saving it with those commands when I first went through it. I don't have access to my printer right now, but I have to assume that's why I'm having the issue. Now I just have to do some tuning. I'll tentatively call this one resolved.
Thanks for all the help, everyone.
if you looking for a cheap easy alternative to leveling your delta search aliexpress for
Automatic Leveling Module Film Pressure Probe
can be bought for around 2 euro.
you just put it on the nozzle for the leveling
