microSD card for 0.6 Duet board with RRFw v 0.78b
What's the full command you are using to get bossa to update it? Terminal or GUI?
There were some guides kicking about that neglected specifying the com port number.
Not sure if you need to erase before uploading with bossa?
@doctrucker it seems one cannot invoke bossa[c] without erasing the CPU : ]
bossac invocation, RepRapPro docs on archive.org
Having got
1.23 dated 2018-12-24b1
installed (and booting), all I get for the cards I've been trying is:Cannot initialise SD card 0: Card is unusable
I have tried 128Mb, 1Gb and 32Gb cards
I expect I should be trying a different capacity/class microSD card.
Have a look over:
@cn said in microSD card for 0.6 Duet board with RRFw v 0.78b:
Having got
Any card up to 32Gb should work, provided it is formatted to FAT16 or FAT32 (which SD cards in that capacity range normally are).
Can you post a close up photo of the back of the SD card socket? Older Duets sometimes have bad soldered connections there.
@dc42 I rechecked messages I was seeing before the upgrade;
Can't open 0:/sys/homex.g to read from. Error code: 3
Macro file homex.g not found.
Will take a close-up when next in the same room as the board.
That looks OK, but you need to look at it from just above the main processor. Sometimes it's evident that the pins on the right hand (as seen from that angle - it's the left hand end in your photo above) end of the row are just sitting on the PCB pads instead of being soldered to them.
Is the SD card pushed into the socket far enough so that it clicks, and you have to push it again to release it?
@dc42 or ?
I try to seat the card properly; have used canned air to blow out to no effect.
Reflowing the soldered joints is next on the list; spare parts are in the post... in case the hot air melts the plastic part
I can't be certain because that part of the photo is a little out of focus; but the joints look OK to me. It's usually clear when the joints are bad.
If the joints at the back of the SD card are bad, it's easier to mend them using a no-clean flux pen and a fine-tipped soldering iron than with hot air.
The other likely possibilities are a bad or damaged contact in the socket, a damaged processor, or a bad soldered joint on one of the processor pins that connects to the SD card. Or just possibly a short (solder bridge) between 2 processor pins, but that's less likely.
Where in the UK are you?
@dc42 Lincolnshire
Have you tried to reading the files on your computer? Have you checked the file system matches what is expected? The duet maybe case sensitive.
@dc42 Lincolnshire
That's a long way from me (Somerset).
@dc42 it is There’s a town here which shares a name with a village down there…
@doctrucker the Duet seems unable to read any microSD cards presently.
Have replaced the microSD socket; the problem persists.
If the Duet used to be able to read SD cards, then sadly the most likely reason it won't now is that one of the microcontroller interface pins is no longer working. It's possible to replace the microcontroller, but not easy. I wrote off the first two Duets that I tried to replace the microcontroller on, by lifting PCB traces. The 3rd and 4th I did successfully.
@dc42 I'm not sure it's ever read uSD cards since I've had it
Hopefully this morning's soldering is still viable ![endoscope view of Duet SD socket]()
https://.chrs.nl/cloud/index.php/s/9q4X9Nfyh9Y9broA new board is outside my current ad hoc budget ...
Was it offered for sale in "known to be fully working" state?
@dc42 was part of a printer listing; operative state unspecified
@dc42 if M122 reports that the board has reset itself via software and/or that the MCU temperature is around/above 100°C the Duet is in a bad way?
