New Steppermotors on all axis ,best setup for this
hi
i have bought new steppermotors
Connection for Stepper is:
A+ = Black
A- = Green
B+ = Red
B- = Bluewhat is the best setup for this steppers ?
thanks
You can wire them to the 4-pin plug with the colours in that order (black, green, red, blue). They are 2A motors, so assuming you have a Duet WiFi or Ethernet (not a Maestro) I suggest you set the current to about 1400mA. If you find you need more torque, you can increase that to about 1700mA. Above that, the motors may get hotter than you are comfortable with.
Hi dc42
thanks for your reply
i have this stepper on each axis so i can set 1400mA on each stepper ?
@lui2004 said in New Steppermotors on all axis ,best setup for this:
Hi dc42
Yes. Normally, the extruder current is the only one that may be at all critical.
ok thanks
i will try first 1400mA
Hi
I would change The extruder motor with The same for z/y/x axis in The first Post is the link.
How much mA i must set up ?
nothing ? do i try with 1400mA ?
@lui2004 On the basis that my extruder stepper motors have about half the the torque of yours and I run them at 80% of max current then try 700mA and see how you get on - you'll soon know if you need to use higher current.
