Solved Maestro motor control problems
Homez works
I looked at the config files and everything looks normal.
I checked the wiring.
I did research on the internet but I did not find anything.
Is it a problem on the board ? -
@patrickb It looks it's reseting itself. Check for shorts when moving.
What power supply are you using to power the Duet? It could be that the PSU can handle a single motor but not all of them.
If you run M122 from the web interface after trying to home all, you will be able to see:
- When the last reset occurred, and why (which will tell you if the hardware reset during the homing attempt);
- What the minimum and maximum VIN voltages were since you last powered up (or the board reset) or ran M122.
Sorry, I do not speak English well. What does "shorts" mean
Even the coupled engines I have the same problem.
I'm not at home, I watch as soon as I get home -
Uncoupled
@patrickb said in Maestro motor control problems:
Short-circuits.
I'm using a 24v 15A power supply.
Here are the results of the M122:
M122
RepRapFirmware for Duet 2 Maestro version 2.02RC5(RTOS) running on Duet Maestro 1.0
Board ID: 08D8M-9T8A2-MQNSS-6JKD8-3SD6M-177LY
Used output buffers: 3 of 20 (13 max)
Static ram: 21236
Dynamic ram: 100436 of which 0 recycled
Exception stack ram used: 212
Never used ram: 9188
Tasks: NETWORK(ready,456) HEAT(blocked,1356) MAIN(running,3672) IDLE(ready,200)
Owned mutexes:
Last reset 00:00:10 ago, cause: watchdog
Last software reset at 2019-05-30 02:16, reason: User, spinning module GCodes, available RAM 9100 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04418000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
SD card 0 detected, interface speed: 15.0MBytes/sec
MCU temperature: min 42.3, current 42.7, max 42.9
Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, read errors 0, write errors 1, ifcount 22, reads 405, timeouts 0
Driver 1: standstill, read errors 0, write errors 1, ifcount 22, reads 405, timeouts 0
Driver 2: standstill, read errors 0, write errors 1, ifcount 23, reads 405, timeouts 0
Driver 3: standstill, read errors 0, write errors 1, ifcount 21, reads 405, timeouts 0
Driver 4: standstill, read errors 0, write errors 1, ifcount 21, reads 405, timeouts 0
Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 411
Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 411
Date/time: 2019-05-30 17:41:40
Slowest loop: 1.69ms; fastest: 0.13ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Bed heaters = 0, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
lcd is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 5.64ms; fastest: 0.02ms
HTTP sessions: 1 of 8
Interface state 5, link 100Mbps full duplex -
Two things wrong:
You are running an unsupported RC version of firmware. Upgrade it to version 2.02 stable.
The board is resetting. If it still happens after you have upgraded the firmware to 2.02, post your config.g and homing files here.
I changed firmware and it works again.
Thanks a lot for your help
