Very strange behavior, CoreXY with external drivers
@capricorn said in Very strange behavior, CoreXY with external drivers:
M669 without parameters reports:
Kinematics is CoreXY, matrix:
1.00 1.00 0
1.00 -1.00 0
0 0 1.00That matrix looks correct for CoreXY. What about M584?
M584
Driver assignments: X5 Y6 Z7 E0:1:2:3:4, 3 axes visible -
That looks OK too. So I think it's either very obscure firmware error or a short-circuit between those two signals (see my earlier message).
to clarify how my extern drivers are connected:
all Step+/Dir+ from the ext. drivers go to +5V.
all Step-/Dir- from the ext. drivers go to the corresponding pins on the breakout board -
all Step-/Dir- from the ext. drivers go to the corresponding pins on the breakout boardThat sounds good.
Are you using G1 S2 moves (after sending G91 to select relative axis coordinates) to test the motors individually?
yes, i did, x and z go together and i can´t find a shortcut...
i also tried to redirect z to drive 8 or 9. Same behavior... -
Do any other motors move when you command the Y motor?
Please check that you really do have +5V on the common 5V feed to the + inputs of the stepper drivers.
no other motors affected by moving Y.
the Voltage at the + inputs of the drivers is 4.56 V -
meanwhile i tested another driver for z-motor (have more of them as spare) and also testet to set the
config to cartesian kinematiks. No luck, always x/z move together.... I´m frustrated.... -
thank you, for your help, i´m just about cabling the printer. i can test it, when everything else is running.
Are you sure that the power to your external stepper drivers is stable? I am wondering whether when they are driving the motors, the voltage could be dropping.
i test that... but i think so, cause i serve 5V to the board with a extern 50W power supply
testet, konstant 4.45V. I take the 5V from the breakout board. Should i take it from the main board?
Or direct of the power supply? -
@capricorn, I mean the main power to your external stepper drivers - 12V, 24V, 36V or whatever you are using.
how do you wire the two power supplies? i think the negative needs to be connected between the two, but i am not 100% sure.
konstant 41V motors driving , i´m using a 600W power supply
i dont think 41v is supported
https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
The Duet 2 (Wifi and Ethernet) work with a VIN supply of between 11V and 25V
@veti
i don´t think so.... -
this is the power for the external motor drivers, not to the duet2
please draw a diagram. this is getting confusing.
including all power supplies and the wires between them.
