Very strange behavior, CoreXY with external drivers
konstant 41V motors driving , i´m using a 600W power supply
i dont think 41v is supported
https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
The Duet 2 (Wifi and Ethernet) work with a VIN supply of between 11V and 25V
@veti
i don´t think so.... -
this is the power for the external motor drivers, not to the duet2
please draw a diagram. this is getting confusing.
including all power supplies and the wires between them.
@veti
that´s easy.12V and 5V go to the duet2
41V go to the external motor drivers -
and how are the power supplies connected to each other?
this are 3 different power supplies. one end each to 220V the other end to the 5v/12v input duet2 and 41v to the motor drivers. No direct connection (except 220V) between them.
see this for the wiring of the duex
https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiringthe entire wiring is about avoiding current flow between gnd connections.
and in your case you have several non connected gnd connections.
not suitable for me, because i have no duex2 oder duex5 board. i have the duet2 ethernet and the expansion breakout bord. the breakout board is only connected by the 50Pin connector
it would still cause a grounding loop.
https://en.wikipedia.org/wiki/Ground_loop_(electricity)there is also a very specific warning for the duet where you have a separate 5v supply via usb.
see
https://duet3d.dozuki.com/Wiki/USB_ground_loops -
hmmmm... now i´m unsure myself.... maybe dc42 can light this issue up?
@capricorn said in Very strange behavior, CoreXY with external drivers:
to clarify how my extern drivers are connected:
all Step+/Dir+ from the ext. drivers go to +5V.
all Step-/Dir- from the ext. drivers go to the corresponding pins on the breakout boardI can not read in its description, where the EN pins of the external drivers are connected.
To the question of groundloops...
is my power distribution ok?
GND (-) from all sources should be a common point, to that the logical levels that reach the external drivers are measured with respect to a single GND of the entire system.
not suitable for me, because i have no duex2 oder duex5 board. i have the duet2 ethernet and the expansion breakout board. the breakout board is only connected by the 50Pin connector
Can you provide photos of your wiring between the expansion breakout board and the stepper drivers, so that I can check it?
@veti said in Very strange behavior, CoreXY with external drivers:
see
https://duet3d.dozuki.com/Wiki/USB_ground_loopsShould not be a problem if the 5V and main PSUs are in the same case, fed by the same mains cable.
I think you won't see much. -
I hope you can see anything. I'm 100% shure, there is nö mistake in the cabling. I checked every single connection more than once, incl. with Multimeter. -
@capricorn You need to connect each ENABLE signal that comes from the breakout board to ENA (-) of each driver.
@jhonf441
No, not necessary and my drivers don't work at all, when connected.
