    I guess I killed it
    650
    • taconite
      taconite last edited by taconite
      Hey guys,
      so I use a Duet 2 Wifi V1.03 with two external drivers for axis U and V. At first I was using DRV8825 but I don't know why but sometimes they didn't. So I bought TMC 2208 V1.1 MKS and because of lacking information I guess I confused the VDD with the VM voltage input.
      That being said I guess I shorted 3.3 and 24V (or fed 24V into the 3.3 rail). I guess that killed the driver, too.
      Now when I power the board all 3 LEDs are on. Diag is just on for couple of seconds.
      I can't connect to the board via WIFI (when I connect over USB, YAT is telling me "modul is being started" but it never starts) and the WIFI modul gets warm.
      Is there a chance to safe the Duet?
      Thanks for your help
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
        If everything is working except WiFi, and nothing (in particular the microcontroller) is getting hot except the WiFi module and possibly the 3.3v regulator (because of the current that the WiFi module is drawing), then there is a good chance that the board can be saved by replacing the WiFi module. With the right tools, it's not hard to replace. When there is over-voltage on the 3.3V rail, the WiFi module and the SD card are usually the first things to fail.
        • taconite
          Thanks David,
          how can I check if anything else ist damaged? The regulator seems to be working (because of the light up LED, right?)
          If I try to run the delta homing (G28) it tells me, that homeall.g couldn't be found.
          Yeah I would give it a shot with the hot air gun to desolder it.
          Custom ANET A8
            dc42 administrators @taconite last edited by
            @taconite said in I guess I killed it:
            Like I said, the other component that fails early when there is excessive voltage on the 3.3V rail is the SD card. Is the card still readable in a PC? Have you tried a different SD card, populated with the system files?
            Is the microcontroller getting hot?
            taconite 1 Reply Last reply Reply Quote 0
            • taconite
              taconite @dc42 last edited by
              @dc42 said in I guess I killed it:
              SD Card holder ist totally cold --> SD card ist still readable with a PC
              microcontroller: It is getting a little warm (but not as hot as the SD card reader) after startup (20s).
              Custom ANET A8
                So you are saying that the SD card is getting hot but still works in a PC? I suggest you measure the voltage on the 3.3V rail, it sounds as though it may be high.
                • taconite
                  No the SD-card and the SD-card-holder are both cold. The microcontroller ist getting a little warm (but is still responsive over USB and YAT).
                  I will measure the 3.3V this afternoon
                  Custom ANET A8
                    If you can get the Duet to recognise a SD card, then it's worth replacing the WiFi module. The first step is to get a successful response from sending M21.
                    • taconite
                      @dc42 So while testing it seems like the 3.3V Regulator died. I measured the voltage on the expansion board ( it indicated 3.2V) and now the yellow LED is not light up.
                      I can't get a connection via USB anymore
                      Custom ANET A8
                      • taconite
                        so I guess my chance are near to zero now?
                        Custom ANET A8
                          The WiFi module may be shorting out the 3.3V rail.
