Corexy Printing very slow - Help please
Hi all. I recently changed my corexy printer from smoothie board to a duet wifi. I have updated to latest firmware everything seemed to be great till I started trying to print.
While jogging the machine everything moves great, but when I upload a gcode file it prints at 8mm/s even though it's set for 300mm/s.
Any advise would be appreciated.
duet uses mm/min rather than mm/s.
in your slicer you need to change the type from marlin to reprap.
@veti going to try that immediately. Thank will let you how it goes.
Can you post your config.g file? YOu may have some speed settings in there set as mm/s when they should be mm/min as well.
Thanks all. I was still on marlin as soon as I changed to reprap everything was back to normal.
