    Duet will not connect to WiFi
    • robaire
      robaire last edited by
      I just finished the assembly and setup of a SeeMeCNC RostockMax V4. I have been unable to successfully connect to my WiFi. I am trying to connect to a 2.4Ghz WiFi network, set to channel 6 (wouldn't work on 11 either). I have tried following various setup guides online but nothing has worked. Any help would be appreciated.
      The terminal simply repeats non-stop:
      WiFi reported error: no known networks found
      WiFi module is idle
      Here is the output from M115:
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet
      FIRMWARE_VERSION: 2.02(RTOS)
      ELECTRONICS: Duet WiFi 1.02 or later
      FIRMWARE_DATE: 2018-12-24b1
      M122:
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917DA-G4MSJ-6JTDA-3SD6R-KSN3A
      Used output buffers: 1 of 20 (11 max)
      Static ram: 25524
      Dynamic ram: 98820 of which 0 recycled
      Exception stack ram used: 360
      Never used ram: 6368
      Tasks: NETWORK(ready,544) HEAT(blocked,1232) MAIN(running,3644) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:46:36 ago, cause: software
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6316 bytes (slot 1)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 26.1, current 26.2, max 26.5
      Supply voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
      Slowest loop: 1.19ms; fastest: 0.08ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 11, completed moves: 11
      Bed compensation in use: mesh
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.03ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is changing mode
      WiFi module is idle
      Failed messages: pending 0, notready 0, noresp 18
      Failed to get WiFi status
      ok
      Error retrieving WiFi status message: bad reply format version
      M587:
      M587: Failed to retrieve network list
      ok
        I wonder if maybe your wifi server version is out of step with the firmware.
        If you place the Duetwifiserver.bin file from the 2.02 release on the SD card and then send M552 S0 to turn off the network module, then send M997 S1 to update the wifi server firmware.
        Then after it reboots, send M552 S0 to disable the wifi module again, and then send the M587 command to add your wifi network and then M552 S1 to re-enable the network module.
