    Need help to config 2-Z Motors and Mesh bed compensation
    617
    • lui2004undefined
      lui2004
      Hi
      i hope you can help me i trying to work 2-Z Motors and Mesh bed compensation. I got strange results from 2-Z Motors and Mesh bed compensation.
      I use the Piezo Orion on my E3D V6
      Cartesian 220x220
      my config.g
      ; generated by RepRapFirmware Configuration Tool v2 on Thu Apr 11 2019 17:51:12 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"AM8" ; Set machine name
      M552 S1 ; Enable network
      M587 S"WLAN-" P"519647189" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S1 ; Drive 0 goes forwards X
      M569 P1 S0 ; Drive 1 goes forwards Y
      M569 P2 S1 ; Drive 2 goes backwards Z
      M569 P3 S1 ; Drive 3 goes forwards Extruder
      M569 P4 S1 ; Drive 4 2nd Z-motor - Normally used as Extruder 1
      ; Motor Remapping
      M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
      ;M92 X100.00 Y100.00 Z400.00 E101.01 ; Set steps per mm
      M92 X100.00 Y100.00 Z400.00 E100.00 ; Set steps per mm
      M566 X600.00 Y600.00 Z18.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; Set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
      M906 X500.00 Y500.00 Z500.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M906 X1400.00 Y1400.00 Z1400.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ;M671 X-15:205:205 Y105:205:15 P2.5 ; für manual bed levelling
      M671 X-20:220 Y0:0 S5.5 ; leadscrews at left and right of X axis für 2 motoren
      M208 X-33 Y-10 Z0 S1 ; Set axis minima
      M208 X220 Y210 Z200 S0 ; Set axis maxima
      ;M208 X-33:220 Y-10:210 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
      M574 X1 Y1 S0 ; Set active low and disabled endstops
      M558 P5 I1 R0.5 H5 F350 ; Set Z probe type to effector and the dive height + speeds
      G31 P500 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
      M557 X10:210 Y10:210 S40 ; Define mesh grid
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S130 ; Set temperature limit for heater 0 to 130C
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S275 ; Set temperature limit for heater 1 to 275C
      M563 P0 D0 H1 ; Define tool 0
      T0 ; Select first tool
      and my bed.g
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v2 on Mon Apr 29 2019 10:01:00 GMT+0200 (Mitteleuropäische Sommerzeit)
      ;G29 ; probe the bed and enable compensation
      G28 ; home
      M401 ; deploy Z probe (omit if using bltouch)
      G30 P0 X10 Y110 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X210 Y110 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      M402 ; retract probe (omit if using bltouch)
      I hope i got some advise whats going wrong
      Thanks a lot
      • Vetiundefined
        Veti
        have you ruled out a mechanical issue?
        after you have done the leveling when you move the head to that position is the head far of the bed?
        • lui2004undefined
          lui2004
          @veti said in Need help to config 2-Z Motors and Mesh bed compensation:
          yes i ruled out the mechanical issues
          i changed the stepper motors the and the Bed and the lead-screws
          after this changes i have made Manual Bed Levelling to make Bed Flat.
          after Mesh the head stays on the last probe point
            You've definitely got some bad probe points in that mesh. Is the bed less stable on that side? Does it bend down more?
            • lui2004undefined
              lui2004
              Hi
              No it does not bend more.
              The nozzle with piezo orion touch the bed and go up.
              But you see The bed is not flat
              Is the config.g and bed.g ok ?
                I think you have your Z max speed set too low. The piezo probe needs a higher speed in order to register a solid contact.
                In your M558 for probe setup you have it set to F350, but in your M203 for Z max speed you are limiting it to Z180.
                So change M203 Z400 and try again.
                • lui2004undefined
                  lui2004
                  thanks Phaedrus
                  it seems a lot better but not perfect right ?
                  what i can do to make it perfect ?
                  sorry my english is bad 😉
                  RepRapFirmware height map file v2 generated at 2019-05-13 20:44, mean error 0.018, deviation 0.057
                  xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                  10.00,210.00,10.00,210.00,-1.00,40.00,40.00,6,6
                  -0.002, -0.057, -0.090, -0.090, -0.077, -0.023
                  0.028, -0.002, -0.047, -0.015, -0.053, -0.023
                  0.010, -0.015, -0.038, -0.027, -0.002, 0.005
                  0.060, 0.055, 0.045, 0.032, 0.048, 0.050
                  0.135, 0.087, 0.068, 0.055, 0.065, 0.110
                  0.142, 0.058, 0.045, 0.010, 0.028, 0.065
                  this is my config.g what i have now
                  M587 S"WLAN-" P"390696406*****" ; Configure access point. You can delete this line once connected
                  M569 P0 S0 ; Drive 0 goes forwards X
                  ; Motor Remapping
                  M203 X6000.00 Y6000.00 Z400.00 E6000.00 ; Set maximum speeds (mm/min)
                  ;M671 X-15:205:205 Y105:205:15 P0.5 ; für manual bed levelling
                  M671 X-33:220 Y0:0 S5.5 ; leadscrews at left and right of X axis für 2 motoren
                  ;M208 X-33 Y-10 Z0 S1 ; Set axis minima
                  M208 X-33:210 Y-10:210 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                  ;M558 P5 I1 R0.4 F300 ; Set Z probe type to effector and the dive height + speeds
                  ;M558 P5 I1 R0.4 F300 X0 Y0 Z0
                  ;M558 P8 I1 R0.6 F300 Z1
                  G31 X0 Y0 Z-0.1 P100 ; Set Z probe trigger value, offset and trigger height
                    I think it is probing perfectly. The heightmap doesn't look too bad. It does look like it's tilted a little lower in the front and higher in the back. You could try mechanically leveling it again to address that, or you could just let mesh compensation do it's thing and correct for the tilt.
                    You can use am STL like this to test if things are working correctly.
                    0_1557775133875_bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                    If you print it twice, once with mesh enabled, and once with mesh disabled, you can see if it's working as intended.
                    • lui2004undefined
                      lui2004
                      Perfect i will Print tommorow
                      And let you know
                      Thanks
