    How to change default x/y speed between G30 probing points?
    • zapta
      zapta last edited by zapta
      My leveling macro has this code to measure at the four leveling screw points
      G30 P0 X26  Y29  Z-99999     ; front / left
      G30 P1 X266 Y29  Z-99999     ; front / right
      G30 P2 X266 Y269 Z-99999     ; rear  / right
      G30 P3 X26  Y269 Z-99999 S4  ; rear / left + report
      Is there a way to speed the x/y movement speed between the probing points? The mesh command M558 supports a speed parameters T but I don't see anything similar for G30.
      Edit: fixed F parameter to T parameter.
        M558 T parameter is the travel speed between points.
        • zapta
          Thanks @phaedrux, is there a similar trick to control the x/y movement speed between G30 leveling points?
            What happens if you set the feed rate before the G30 lines?
              dc42 administrators @zapta last edited by
              @zapta said in How to change default x/y speed between G30 probing points?:
              The same parameter controls both.
              zapta 1 Reply Last reply Reply Quote 0
              • zapta
                zapta @dc42 last edited by
                @dc42 said in How to change default x/y speed between G30 probing points?:
                Thanks dc42. I tried to add T10000 to the G30 commands but it doesn't see to affect the x/y movement between the probing points.
                G30 P0 X26  Y29  Z-99999 T10000     ; front / left
                G30 P1 X266 Y29  Z-99999 T10000     ; front / right
                G30 P2 X266 Y269 Z-99999 T10000     ; rear  / right
                G30 P3 X26  Y269 Z-99999 T10000 S4  ; rear / left + report
                Is this the right parameter to use with G30? Any idea how to control the x/y travel speed between G30 probing points?
                  No that format is not quite right.
                  The T value goes in M558 in your config.g, not in the G30 command in bed.g.
                  What happens if you add G1 F10000 before the G30s?
