    Unable to display duet web interface
    413
    • Tom732
      Tom732 last edited by
      Unable to display duet web interface. I follow the instructions exactly. Duet says it's connected to my router but I can't see it in the router settings.0_1557939426711_duet 1.png 0_1557939544175_duet 2.png Thank you for your help
      • dragonn
        dragonn last edited by
        just enter the IP address directly, it works much better this way.
        • Tom732
          • A Former User
            A Former User last edited by
            did you copy the DWC files to your sd card /www folder?
            • Tom732
              I'm not sure the dwc file says nothing. I followed the instructions and there is nothing about copying DWC is nothing. Are there instructions somewhere? Do you have firmware on your sd card?
              • Tom732
                  dc42 administrators @Tom732 last edited by
                  @tom732 said in Unable to display duet web interface:
                  That message means that the firmware didn't find the web files in the /www folder of the SD card. if it's a genuine UK-manufactured Duet then all the files should already be present on the SD card. See https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_SD_card_structure.
                  • A Former User
                    if that was still unclear and you somehow formatted your card, just grab the zip file from https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents
                    Extract the /www directory from the zip file to your sd card /
                    • Tom732
                      Thank you for your help, the board is clone and I did not load the DWC on the card along with the weak receiving signal of the ESP module I immediately lost the signal. It helped put the board closer to the router.
