    I think my 2nd extruder driver is fried.
    • viet
      viet last edited by
      Hello, I was instructed by Tim from Filastruder and Tony from Duet3D to post here.
      My Duet 2 WiFi has been working fine for a few months now. Today I wanted to add another extruder. I configured it. Turned off the printer. plugged it in. I'm not sure if when I restarted the duet or if I tried to extrude, but I heard this popping noise and a burning smell. After that, I saw "Error: short-to-ground reported by driver(s) 4" on my screen. There is a weird mark on the last stepper driver. I'm almost sure that was a popping noise. The 2nd extruder would not work.
      I came across this post: https://forum.duet3d.com/post/29722
      Is it possible my board can be repaired or replaced?
      • elmoret
        elmoret last edited by
        @dc42 / @T3P3Tony
          Hi viet,
          Please check the wiring between that stepper driver output and the motor carefully for short-circuits. If you are satisfied that the wiring is sound, I approve a replacement or repair under warranty.
          • viet
            viet last edited by
            Hello I carefully checked the wiring between the problematic stepper driver output and the motor for short-circuts. I appreciate your approval for replacement of repair.
