    First Layer
    781
    • npm1undefined
      npm1
      I've shifted over from einsyrambo, and like my previous experiences with the duet it is awsome. However for the life of me the first layer seams the same issue as before it appears slanted on the bed as shown in the pictures below
      Please Help, This is the same issue as with the pervious time.
      npm1undefined 1 Reply Last reply Reply Quote 0
      • npm1undefined
        npm1 @npm1
        This post is deleted!
          How are you leveling the bed?
          If it's an i3 style X gantry how are you leveling each side of it?
          Are you using mesh compensation?
            It looks to me like a classic case of dual Z motors being out of sync. Does the printer have dual Z motors?
            • npm1undefined
              npm1
              @Phaedrux
              yes i am, and have just recently added G29 S1 straight after G29; in the gcode
              How would I sync the motors I forgot.
                https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                • npm1undefined
                  npm1
                  Not to worry I think I've resolved the issue.
                  GUIDE & TIPS
                  -Ensure that axis minima on the Z axis is set up as a negative value especially for prusa style printers, as to avoid any premature errors
                  -Probe at intended heat and save height map.
                  -Reload the heightmap through G29 S1 after probing G32 in GCODE of all prints
                  -Run G29 every other day with a spacing range of 10-20.
                  -Include G29 S1 in the bed.g,
                  -reestablish the z=0 datum by using G30 F300
                  For any one looking out for config to work backwards from, DO NOT UPLOAD AND USE, use only for reference purposes.
                  ; bed.g
                  ; generated by RepRapFirmware Configuration Tool on Mon Apr 09 2018 16:57:18 GMT+0100 (GMT Daylight Time)
                  ; Probe the bed at 4 points
                  G30 P0 X15 Y20 H15 Z-99999
                  G30 P1 X15 Y195 H15 Z-99999
                  G30 P2 X215 Y195 H15 Z-99999
                  G30 P3 X215 Y20 H15 Z-99999
                  G30 P4 X92 Y90 H15 Z-99999 s
                  G1 X92 Y90
                  G30 F300
                  G29 S1;
                  *; Axis Limits
                  M208 X0 Y-40 Z-2 S1 ; Set axis minima
                  M208 X250 Y210 Z200 S0 ; Set axis maxima
                  M564 S0 H0
                  M574 Z2 S2 ; Set endstops controlled by probe
                  M558 P5 H25 F360 I1 T6000 ; Set Z probe type to modulated and the dive height + speeds
                  G31 P500 X13 Y20 Z-0.5; Set Z probe trigger value, offset and trigger height
                  M557 X15:220 Y20:195 S10; Define mesh grid
                    Phaedrux Moderator @npm1
                    @npm1 said in First Layer:
                    I find it strange that your trigger height is negative. That would imply that your nozzle is below the bed surface when the probe triggers.
                    • npm1undefined
                      npm1
                      @Phaedrux if I was to set to positive it drags through the PEI, this just gives me a chance to baby step on each print, this still being tweaked but the main thing for me is it not dragging through the sheet
                      • npm1undefined
                        npm1
                        So I've done further tweaking, and i might be onto something...
                        I ran M48.g as describe by this post: M48
                        M292
                        G32 bed probe heights: -0.024 -0.013 -0.021 -0.012 -0.025 -0.020 -0.025 -0.030 -0.022 -0.041, mean -0.023, deviation from mean 0.008
                        Before I did this i was tweaking my bed according to the heightmap.csv
                        01:25:46
                        G29 S0
                        9 points probed, min error -0.048, max error 0.136, mean 0.029, deviation 0.054
                        Height map saved to file heightmap.csv This was done when heated at PLA Temps
                        Its looks like the following:
                        RepRapFirmware height map file v2 generated at 2019-06-28 01:25, min error -0.048, max error 0.136, mean 0.029, deviation 0.054
                        xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                        25.00,195.00,0.00,195.00,-1.00,70.00,70.00,3,3
                        0.063, 0.026, 0.043
                        0.064, -0.007, -0.048
                        0.136, 0.029, -0.043
                        When cold it looks like the following:
                        RepRapFirmware height map file v2 generated at 2019-06-28 01:14, min error 0.014, max error 0.267, mean 0.111, deviation 0.071
                        0.161, 0.090, 0.110
                        0.154, 0.051, 0.014
                        0.267, 0.101, 0.048
                        The question is, what do you reckon, do you see these tweaks improving my first layer...?
                        For any one interested in the files, visit the Github Page:
                        Github
