pt100 1.2 ?
Any news on the pt100-board version 1.2 with the capacitors anyone?
Or a step-by-step explanation by someone how to add them myself and what type of capacitors where on the board... this post https://forum.duet3d.com/topic/11337/pt100-wiring/4 does it not make 100% clear for me...
After thinking a while about it, I think the pcb should not include the capacitors but only soldering/trough-wire place(s) for it with some sort of step-by-step-guide what and how to add them, so that you first have to get your wiring right and maybe add them later yourself if it just doesn´t get better... (like in my case
Would be really great!
PT100 v1.2 boards have already been shipping for several weeks. The first production batch did not have the capacitors fitted, because there wasn't time before assembly to verify that adding them had no bad side effects.
@dc42 does it makes sens to add the capacitors if I have an older board?
What values they are? -
@dragonn if you have the same problem, could be worth a try. values and procedure described if you follow the links
which would have lead you here https://forum.duet3d.com/post/17297
