Relation between delta towers and slicer X and Y axis
  • Hi,
    i d'like to know what relation there are between position of a towers in a delta printer, a axis of slicer, a cartesian system, and the correct socket where i have to connect steppers....
    01 - What its the correct conexion of towers motors. Clockwise X-->Y-->Z, or anti clockwise X<--Y<--Z?
    02- What its relation between slicer cartesian, and towers. X axis of slicer, point to a tower? X Delta tower or other tower? or X axis of slicer point between Delta towers? X axis of slicer, point to midpoint between X(Delta tower) and Y(Delta tower)
    The X tower should be on the left, the Y tower on the right, and the Z tower at the back.
    By default, the +X direction will be to the right, and +Y will be to the rear. This can be changed if necessary using the M665 ABC parameters. X0 Y0 will be the centre of the bed.
