    Is there a minimum speed or step pulse rate?
    • bot
      bot last edited by
      My extruder axis is having trouble with consistency. It is being run at approx 0.033 mm/s in an extreme example of small, slow extrusion paths.
      Is this too slow? It's set at approx 4700 steps/mm.
      Is there any way to maximize accuracy of each step for such slow speeds?
      *not actually a robot
        Maybe you could double down on your steps per mm and use higher microstepping for the extruder.
