Rotating magnet filament monitor - frame errors?
@dc42, is there anything else I can do for now or should I contact Filastruder to issue a warranty return?
@dc42 @T3P3Tony
The replacement filament monitor arrived today - thanks for the really fast and painless swap!Just installed, gave it a quick go ...
- no more "Sensor not working" messages
M591 D0
reports quite usable dataDuet3D rotating magnet filament monitor v2 on input 3, disabled, sensitivity 25.33mm/rev, allow 85% to 115%, check every 3.0mm, current pos 14.8, measured sensitivity 25.21mm/rev, min 90% max 110% over 1252.5mm
M122
reports no frame errors anymoreExtruder 0: pos 14.77, ok, measured sens 25.21mm/rev min 90% max 110% over 1252.5mm, errs: frame 0 parity 0 ovrun 0 pol 1 ovdue 0
Will do some more tests in the coming days, but those are by far the best results I was ever able to get!
Thanks to both the teams of Filastruder and Duet3D for your great support!
Much appreciated!
