Solved Touch Mi turning off when trying to do mesh bed leveling
Hello ,
I have a problem and i don't know what is causing this
i can do z probing fine set offset , ext... but when i try to to meshbed leveling the probe turn off
you can see it on the videoit drive me crazy because i don't see anything that can turn off the probe like that (didn't find any Gcode for that fonction too )
Thank you for any help you can provide to me !
here is my file :
; bed.g
; generated by RepRapFirmware Configuration Tool v2 on Wed Jul 31 2019 22:31:25 GMT+0200 (heure d’été d’Europe centrale)
G29 ; probe the bed and enable compensation; deployprobe.g
; this is a manual probe deployment by touching the Touch-Mi Probe
; with the magnet included.G91 ; relative positioning
G1 Z10 F600 S2 ; lift Z relative to current position
G90 ; absolute positioning
; G1 X0 F1800 ; move X to zero
; G1 y0 F1800 ; move y to zero
M291 P"Trigger Magnet" S3 ; prompt for magnet action; retractprobe.g
G0 Z0.5 ; dive to retract probe with magnetic ball bearing; homez.g
; called to home the Z axis
G1 Z10 F200 S2 ; lift Z relative to current position
M401 ; deploy probe
G1 X150 Y150 F200 ; go to first probe point
M402 ; retract probe; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F60 ; lift Z relative to current position
;G90 ; absolute positioning; Configuration file for Duet WiFi (firmware version 1.21)
; generated by RepRapFirmware Configuration Tool v2 on Wed Jul 31 2019 22:31:25 GMT+0200 (heure d’été d’Europe centrale); General preferences
M83 ; ...but relative extruder movesM667 S1 ; Select CoreXY mode
M550 P"Duet2printer" ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Physical drive 0 goes backwards
M569 P1 S0 ; Physical drive 1 goes backwards
M569 P2 S0 ; Physical drive 2 goes backwards
M569 P3 S0 ; Physical drive 3 goes backwards
M569 P4 S0 ; Physical drive 4 goes backwards
M350 X128 Y128 Z128 E128:128 I1 ; Configure microstepping with interpolation
M92 X800.00 Y795.20 Z3244.00 E3472.00:3472.00 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; Set accelerations (mm/s^2)
M906 X1100.00 Y1100.00 Z800.00 E1200.00:1200.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X0 Y20 Z0 S1 ; Set axis minima
M208 X280 Y320 Z250 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; Set active high endstops; Z-Probe
M558 P8 F500 H3 I0 T4000 ; Set Z probe type to touch mi and the dive height + speeds
G31 P500 X-14.0 Y-42.1 Z5.2 ; Set Z probe trigger value, offset and trigger height
M557 X60:250 Y60:300 S150 ; Define mesh grid; Heaters
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 2
M143 H2 S280 ; Set temperature limit for heater 2 to 280C; Fans
M106 P1 S1.0 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
M563 P1 D1 H2 ; Define tool 1
G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
Hi ,
i have find the reason for this happening
it was the cable it was too thin , i change it and it work now
