Struggling with bed level, delta with duet and smart effector
Hi
I've got a delta I built based on DC42's blog and in general it is fine, but Im having a nightmare getting the first layers down, the right and back of the bed have a high point no matter what i do in the config/mesh etc
It seems like after the probing and mesh creation that its just not getting used, so I wonder if someone could look over my setup and tell me where im being stupid please
the ally bed plate on the printer is toolplate, so is flat, I'm still deciding if to go with magnetic sheet and perspex or glass and printbite or similar, ideally would love a removeable flex plate, but thats for another post as dont want to confuse this one too much
config files are below /attached
3_1566722649408_homedelta.g 2_1566722649408_config-override.g 1_1566722649407_config.g 0_1566722649406_bed.g
system version is
firmware wifi : duet 1.02 or later
version : 2.04rc1 (2019-07-14b1)
wifi version : 1.21
web interface : 1.22.3bedmesh console info and view
example gcode (severely truncated)
0_1566722948499_example gcode produced from slicer .txtthe basis of my leveling is .....
run delta calibration min of 3 times till it stabilises on resultsrun m666 and m665, take these values and put in config.g as a baseline setting
then run the bed mesh calibration
then set nozzle to bed with a4 paper to give estimated 1st layer height
g92 z0 = set nozzle to zero
g1 z5
g30 s-1 = sensor trigger (do it multiple times - check consistent resultsthis gives z value for nozzle offset / first layer height
in config.g file
g31 z compensation ... put z value inafter all of this, it starts printing, but is still high on the right size and a point on the back, which is what i thought the bed mesh would resolve
hope its something stupid
Thanks for reading
Phil
forgot to add, the current bed is sanded perspex held down with bulldog clips, not ideal long term but its a starting point, all calibration is done with a cold nozzle else it would melt the perspex on probe
I do check there is no filament on end of nozzle before running the calibration etcThanks
Phil
Can anyone please offer any help / direction i should take please ?
What are your results on doing the autocalibration?
@phillawrence said in Struggling with bed level, delta with duet and smart effector:
Hi
Nope. Enter M500 from the console instead. This stores the values in config_override.g
(You already, correctly, have M501 at end of config.g to fetch these at boot. )then run the bed mesh calibration
Good.
g1 z5
in config.g file
g31 z compensation ... put z value inNope. Don't do ANY of that.
Instead, be sure there is a G29 S1 in your slicer's start g-codes, to invoke the saved mesh map.I also run a G32 in my slicer's start gcode, to re-probe (calibrate) the bed before every print. My bed.g does a 16 point, 8 factor, for these pre-print calibrations. Fairly fast, and works great. This is entirely optional.
@Danal thanks, it looks like i was missing the g29 s1 in the slicer code, so it was ignoring all the good work before hand lol
@oliof thanks, autocalibration was bringing good results back, it looks like the slicer was ignorning the bed mesh, as I had not added the g29 s1 (live and learn)
Cheers
Phil
