RRF.org EMF Calculator bug/feature
In the EMF calculator, the inductance field is restricted to 1 mH or more. I have encountered a stepper motor with 0.63 listed, but the calculator will not accept it. Is there a reason for it?
I see that the calculations seem to work anyway, even though the field is highlighted in red, so there doesn't seem to be a problem with the functionality but just with the visual feedback... It caused me to stop inputting my values, when if I had continued everything would be (seemingly) fine.
@chrishamm can you have a look at this when you get a chance please.
Thank you. It’s definitely not urgent, as the calculator indeed works fine with a value below 1. It’s just slightly confusing.
Great calculator tho. I reference it constantly. Thanks.
Thanks for your report, I lowered the minimum inductance to 0.1mH.
