    Set of multiple fans triggered by multiple individual heaters?
    • gnydick
      gnydick last edited by
      I have 2 fans on my print carriage as I have a dual extruder setup. I would like them both to be thermostatically controlled and both of them to turn on when either heater turns on. Is that possible?
      • nhof
        nhof last edited by
        Yes you can hook up thermostatic mode to multiple heaters.
        So your code might look something like this:
        M106 P0 H1:2 T45:65 ; fan0 controlled by H1 and H2, ramps up from 45-65C
        M106 P1 H1:2 T45:65 ; same for fan1 output.
        If they will always be controlled together you can just use one line of the above and connect both fans to one output.
        • gnydick
          oh, duh, i forgot about using ':' for specifying multiples. Thanks!
