SD card slot failed in Duet wifi
hello I get in touch with you to tell you the problem I have with the duet2 wiffi motherboard, after trying many configurations with 3 sd cards, I have seen that the problem I have is with the sd module because after reading on github I have discovered The problem does not recognize the SD cards, because the module is broken, I wish I could change it for another motherboard or repair it, thanks
How old is your Duet, and where did you buy it?
Hello, I acquired it in a joint here in Spain, from Mr. Hector de la Fuente, on May 9, 2018
As the warranty terms varies with vendors/countries you'll need to check with the vendor if your board is still under warranty.
@bearer hello I think the warranty issue is important but I have not manipulated the card at any time I do not know if it was because those who brought the capacitor c111 that was wrong, I have not disassembled the card has never worked perfectly until last week and doing all the steps of github I discovered that this is the fault, thanks
As you haven't bought the board from duet3d.com all that can happen here is the administrators determining if the problem is covered by warranty.
The first step is to determine if the board is still under warranty, if not there is no point in examining if the problem is covered by the terms of the warranty, as such your task is to ask the vendor if the 18 months old board is still covered by warranty.
Some parts of the world offer 6 months warranty, some 24 months, as such you need to ask your vendor.
If Mr. Hector is the proprietor of https://tienda.bricogeek.com/content/3-condiciones-de-uso#garantia (the genuine spanish reseller) then the terms seems to not cover your case as it is a problem that occured after 6 months, and cannot be proven to have been present at the time of delivery as the card initially worked?
In any case:
@bearer said in SD card slot failed in Duet wifi:
304/5000
man if the card was 5 years old, I understand that duet washes his hands, but is bought last year and as I say I have never manipulated the card, I have trusted duet and I do not see normal that the card fails without touching it and is my fault, thank you and I hope the duet team gives me a solution -
They asked you a question; your answer doesn't answer what they wanted to know; in plain terms is it a genuine Duet board purchased from an authorized reseller? And in any case you need to direct your claim to your seller, refer to https://www.duet3d.com/warranty
@bearer of course it is original and if purchased from an official distributor, it is not a problem of use it is a problem of the card that fails the sd module, and excuse me if I do not write well, it is through the google translator, thanks
Okay, thats one step closer, next determine the distributors warranty period for your purchase.
@bearer One question, if the warranty has already passed, what options do I have to repair the card? I do not know what to do
EU consumers usually have good protection from vendors beyond manufacturers warranty, but I'm not familiar with your country, your vendor will be able to answer you.
If all else fails, and you're certain the problem is the sd-card reader on the board, then I'd take it to a cell phone repair shop and ask them to replace the sd-card socket. However your the second picture you posted does say the card is detected, but its still possible other pins of the socket is damaged. Does the problem persist if you disconnect any other accessories (while powered off)?
Ahh i missed that.
@GOYO i don't think is the card detect pin then, although that is by far the most common issue of the SD card has been working fine up until now. and normally over many 1000s of insert/removes.
@t3p3tony hello, I have not removed the card since I mounted it last year, this week I started not to connect and started looking at the github and I noticed by other users who also had that problem, I did all the checks that Mr. DC42 explained to another user and I realized that I had the same problem, as I say I have not released the SD since last year that the mount in the duet
@bearer I had never removed the card until now that I had a connection error, I have a cr10 and the electronic box has been closed until now
@t3p3tony
I've been like this for 3 days
@goyo please send a good picture of the SD card socket showing how it is soldered on, and also a picture around the processor. Also i note your MC temp of 40 degrees, thats probably not calibrated, does it feel hot to the touch?
This post is deleted! -
the processor is not hot
