    Cannot get WIFI to work on a new Duet3D WIFI
    200
    • jeffvan302
      jeffvan302 last edited by
      I have a new Duet3D 2 WIFI board and cannot get the WIFI to work.
      I keep getting:
      WiFi reported error: no known networks found
      WiFi module is idle
      On the physical WIFI module the blue led flashes once when the board gets power, and that is it. No more flashes at any other time.
      I updated the firmware with the files from the Release 2.03 (Duet 2 series), 1.24 (Duet 06/085) release.
      I used the M997 S0 and M997 S1 with the following files in the sys folder:
      Duet2CombinedFirmware.bin
      DuetWiFiServer.bin
      iap4e.bin
      M587 has two WIFI options (I have both available):
      COMEYSAFEHOUSE IP=10.240.0.240 GW=10.240.0.1 NM=255.255.255.0
      JEFFPIXEL IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
      Running M122 I get the following:
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-956GU-DGMSN-6J1F4-3S86T-1BR3G
      Used output buffers: 1 of 24 (10 max)
      Static ram: 25680
      Dynamic ram: 93644 of which 0 recycled
      Exception stack ram used: 320
      Never used ram: 11428
      Tasks: NETWORK(ready,548) HEAT(blocked,1236) MAIN(running,3652) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:05:01 ago, cause: software
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11428 bytes (slot 1)
      Error status: 0
      [ERROR] Error status: 0
      Free file entries: 10
      MCU temperature: min 32.2, current 33.3, max 33.5
      Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Cache data hit count 742554272
      Slowest loop: 34.60ms; fastest: 0.08ms
      Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.24ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is changing mode
      WiFi module is idle
      Failed messages: pending 0, notready 0, noresp 1
      Failed to get WiFi status
      Error retrieving WiFi status message: bad reply format version
      [ERROR] Error retrieving WiFi status message: bad reply format version
      From what I have read the "[ERROR] Error retrieving WiFi status message: bad reply format version" error means a mismatch between the "DuetWiFiServer and the the Duet main firmware".
      With the M997 S0 and M997 S1 commands, I thought I would get the correct versions uploaded. Some additional information would be appreciated.
      Thank you!
      Jeff
      • nhof
        nhof last edited by
        Do you know which version of the wifi server firmware you have installed? Looks like v 1.23 and 1.24 should be compatible with main firmware 2.03
        Additionally make sure the network you are connecting to is 2.4GHz and not 5GHz. The esp chip only supports 2.4GHz networks.
        • jeffvan302
          I took the DuetWiFiServer.bin file from the same zip file of the 2.03 release. I got the Duet2CombinedFirmware.bin file from the same link.
          I am not sure how to check the version of the DuetWiFiServer.bin file.
          I hope that sheds some light on the issue.
          • A Former User
            A Former User last edited by
            Breifly looked at the 2.03 bundle and the wifi server version was 1.23, but not sure if there are better ways to tell which version the binary is, but on linux strings and grep usually works, not always as simple as grep version though.
            bearer@rama:/tmp  $ strings DuetWiFiServer.bin  | grep version
            version=1.23
              Are the SSIDs of your networks exactly as M587 reports them? SSIDs are case sensitive. Are they definitely broadcasting on 2.4GHz, and not hidden?
              • A Former User
                Maybe Wifi issues should be accompanied by a screenshot from an android/iphone app that shows wifi networks, channels, encryption types and signal strengths in the same location as the Duet. Its been a while since I've looked at those - but others may have up to date reccomendations.
                Back to topic;
                as jeff points out it suggests wrong versions, @dc42 would the firmware issue those messages if the versions were right but no networks were found, i.e. empty replies?
                  dc42 administrators @Guest last edited by dc42
                  @bearer said in Cannot get WIFI to work on a new Duet3D WIFI:
                  Back to topic;
                  No. The only known reason for that message is mismatched firmware versions, however there have been a few reports of it, so I am starting to suspect a bug. Recommended workaround when you get it: send M552 S-1, then M552 S0, then try the original command again.
                  jeffvan302 1 Reply Last reply Reply Quote 0
                  • jeffvan302
                    jeffvan302 @dc42 last edited by
                    It looks like I got it to work. Here is what I ended up doing:
                    The M552 S-1 followed by M552 S0 seems to reset the WIFI unit and now it reports the following with the M122 command:
                    >>> M552 S-1
                    SENDING:M552 S-1
                    WiFi module stopped
                    ok T0:2000.0 /0.0 B:2000.0 /0.0
                    >>> M552 S0
                    SENDING:M552 S0
                    WiFi module started
                    >>> M122
                    SENDING:M122
                    Used output buffers: 1 of 24 (1 max)
                    Static ram: 25680
                    Exception stack ram used: 308
                    Never used ram: 11440
                    Tasks: NETWORK(ready,1280) HEAT(blocked,1236) MAIN(running,3820) IDLE(ready,160)
                    Owned mutexes:
                    Last reset 00:01:52 ago, cause: power up
                    Error status: 0
                    MCU temperature: min 24.4, current 30.3, max 30.3
                    Cache data hit count 255064556
                    Slowest loop: 99.46ms; fastest: 0.07ms
                    === DDARing ===
                    Segments left: 0
                    === Network ===
                    Slowest loop: 1.25ms; fastest: 0.00ms
                    - WiFi -
                    Network state is running
                    WiFi module is idle
                    WiFi firmware version 1.23
                    WiFi MAC address dc:4f:22:6e:6f:a8
                    WiFi Vcc 3.42, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 30176
                    I can now see the WIFI firmware version as 1.23.
                    On WIFI Frequency. I have separate SSIDs for difference Frequency sets. So yes these are 2.4GHz networks.
                    On the issue of Wifi SSIDs: They are not the same. There are lowercase letters in the SSIDs and I enter them as such with the M587 command. But when I check the list with the M587, all the characters are upper case. The same is happening to the Passwords. I discovered this when I added an SSID with all uppercase letters into my WIFI access point but with lowercase letters in the password. I was getting "WiFi reported error: Wrong password while trying to connect to JEFFPIXEL". I then created an uppercase password and now the system connects. The sequence of commands that I used are as follows:
                    M552 S-1                          ---Stops the WIFI Module
                    M552 S0                           ---Starts the WIFI Module
                    M122                              ---Checks the status of the board (WIFI status at the bottom)
                    M588                              ---Cleared all old SSIDs
                    M587 S"" P""                      ---Entered the new SSID with uppercase SSID and password.
                    ---I made sure to have a WIFI SSID and Password that matched all uppercase letters.
                    M552 S1                           ---Connect to WIFI
                    ---(After a few seconds)
                    M122                              ---Check status of WIFI at the bottom
                    The last command yielded the following for the WIFI section:
                    - WiFi -
                    WiFi flash size 4194304, free heap 25296
                    WiFi IP address 10.240.0.240
                    WiFi signal strength -51dBm, reconnections 0, sleep mode modem
                    I can now ping the board on the network.
                    Thank you
                    Jeff
                    fcwilt dc42 2 Replies Last reply Reply Quote 0
                    • fcwilt
                      fcwilt @jeffvan302 last edited by
                      @jeffvan302 said in Cannot get WIFI to work on a new Duet3D WIFI:
                      Just out of curiosity why do you have separate SSIDs for different channels - I guess that is what you mean by "frequency sets".
                        dc42 administrators @jeffvan302 last edited by dc42
                        That's because you are using the wrong program on your PC to connect via USB. The reason we tell you to use YAT (if using a Windows PC) is that common GCode senders such as Pronterface convert everything you enter to uppercase.
                        Please check that you don't have any M587 or other network-related commands in config.g, other than M552 S1 to connect to the access point.
                        • jeffvan302
                          jeffvan302 @fcwilt last edited by
                          @fcwilt said in Cannot get WIFI to work on a new Duet3D WIFI:
                          It just makes it a lot easier to know if you are connected to 5Ghz or 2.4Ghz. On my cell phone I can forget the 2.4GHz name and just connect to the 5GHz name. That way I know I am always on 5GHz. It really is just an easy diagnostic tool. It also allows you to know if any device can only connect to 2.4GHz, if all that is available is the 2.4GHz SSIDs.
                          • jeffvan302
                            @dc42 said in Cannot get WIFI to work on a new Duet3D WIFI:
                            Thank you for the info on YAT.
                            I only had the M552 S1 in the config.g file at first (No M587), while the issues were occurring.
                            I have since the last test added the following:
                            M552 S-1					   ; Stop WIFI Module
                            G4 P2000				           ; Wait 2 seconds
                            M552 S0						   ; Start WIFI Module
                            M552 S1
                            And now it boots and connects to the network without any issues.
                            Let me know if I should make any changes.
                            Thank you!!!
                            Jeff
                              I am surprised that adding those commands makes any difference, because the M552 commands get deferred until config.g has completed. Or at least, that's what is supposed to happen. Are you sure it still doesn't work with just M552 S1 in config.g?
                              • jeffvan302
                                I removed the commands and just have M552 S1 now and it does still connect. I guess the M552 S-1 followed by M552 S0 was only needed after the firmware upgrade.
                                Thank you.
                                Jeff
                                • Nuramori
                                  Nuramori last edited by
                                  This post is deleted!
