SOLVED M350 STEPPER MODE
M350 stepper mode. Im running a duet wifi w with a cr10- s5. Does any one have the orininal settings for
M350 and and m906 for a cr10-s5 running latest firmeware
I think you may have already found what you needed in another thread, but here's some info that may help you understand.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M350_Set_microstepping_mode
https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents
For microstepping it's usually best to use x16 with interpolation to x256. This puts less strain on the CPU and gives the benefit of silent smooth operation.
M350 X16 Y16 Z16 E16 I1
For motor currents in order to set the correct value you need to know what the rated max current of your motors is, then set M906 to be ~70-85% of that. So if the motor max is 1000ma, set M906 to 800.
Awsome thanks.
