    Prusa MK3 - Stall detection help
    • dismaniaundefined
      dismania
      I am just now swapping my Prusa MK3 over to a bear frame and using the Duet Wifi 2 board. I cannot for the life of me get this thing to home correctly. I am using the default Prusa LDO motors. Can someone share the settings for config.g and the home ones so I can see what I am doing wrong? Thanks!
        I haven't used those particular motors, but the guide to using stall detection is at https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing. I find a stall sensitivity of about 3 in the M915 command is good for most motors.
        dismaniaundefined 1 Reply Last reply Reply Quote 0
        • dismaniaundefined
          dismania @dc42
          @dc42 I think my home commands are not correct. Can you share an example of what it should look like?
            Phaedrux Moderator @dismania
            @dismania said in Prusa MK3 - Stall detection help:
            See the link provided above.
            • OBELIKSundefined
              OBELIKS
              Chris Warkocki made the settings for Duet and MK3.
              See here: https://www.patreon.com/posts/duet-prusa-files-30115916
              But try not to just copy the settings, see what he did and try to implement it in your settings.
              P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
              Original Prusa i3 MK3S
