M122 add actual and max current measured by TMC
With Marlin and TMC2208, if I send M122 gcode, it show the actual current used by each steppers (http://marlinfw.org/docs/gcode/M122.html](http://marlinfw.org/docs/gcode/M122.html).it's possible to add in DWC the followings output with M122:
X Y Z E0 Set current 850 850 850 800 Run current 826 826 400 800 MAX current 1165 1165 600 900 Hold current 500 500 500 500
