Whats the gcode that allow negative movements?
  • hi,
    I can remember, and i cant find it in WiKi....
    Thanks
  • G1 Xnnn Ynnn Znnn H1 Sense endstops while moving (ignoring the axis limits). On Delta (only), axis letters refer to individual towers.
  • Hi,
    Perhaps you are thinking of M564?
  • ...........or simply G1 X-nnn Y-nnn Z-nnn to move in the negative direction. The title question is a bit ambiguous so we can only guess the answer.
  • Later try.... But think its M564... I have changed from volcano heatblock to standart... The printable área has changed, and i want to adjust it
    Thanks
  • I think you want to change your axis limits in your config.g file...that would be the M208 line.
    This is what I have for my BLV CoreXY printer
    M208 X-2.5:340 Y-0:328 Z450 ; X carriage moves from -2.5 to 340, Y bed goes from 0 to 328
    Basically when my carriage hits the x endstop the nozzle is -2.5mm left of my bed and the max movement I want to the right is 340mm... my y homes at the max which is 3mm past the back of my bed which which is 340mm wide x 325mm deep..
