Themistor settings
I had to plug in a standard E3D Themistor onto my Duet2wifi
and now im trying to setup the code for it.I have it plugged in E0 sensor on board
This is my code but i cant get a reading so far
M143 S280 ; Set maximum heater temperature to 280C
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M305 P0 T100000 B4138 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0 - PT100
M305 P1 T100000 B4725 C7.060000e-8 R4700 H1
M143 H1 S280 ; set temperature limit for heater 1 to 280Cwould apprecaite some help, Im not great with decifering gcode
That does look correct for an E3D thermistor, but I don't think you should be using H1.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M305_Set_temperature_sensor_parameters
Hnnn If the sensor is a thermistor, this is the ADC high offset. If it is a current loop sensor, this is the temperature when the current is 20mA.
