3.0beta10 on duet2eth temperatures behaving weird
M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0beta10 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-09-12b1
disconnect all three thermistors, enter
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 M308 S1 P"e0temp" Y"thermistor" T100000 B3950 M308 S2 P"e2temp" Y"thermistor" T100000 B3950
show error on all three (M105 show -273.1 as expected)
attach thermistor on bed - show ok for bed, -273 for e0, e1 (expected)
detach th from bed, attach one to e0, one to e1, e0 show ok 26C, bed and e1 show -273 (not expected for e1)
disconnect e0, e0 shows 26, e1 show -273, bed show -273 ?!?!?!?
further testing, e0temp pin name is reading from the left connector ( E1 thermistor2 according to image of the pinout) weird ..
now it gets weirder
thermistor attached to e0temp and e1temp
M308 S1 P"e0temp" Y"thermistor" T100000 B3950 M308 S2 P"e1temp" Y"thermistor" T100000 B3950 M105 T0:26.5 /0.0 T1:-273.1 /0.0 B:-273.1 /0.0
ok, T1 is not reading but... check this:
M308 S2 P"e2temp" Y"thermistor" T100000 B3950 M105 T0:92.0 /0.0 T1:-273.1 /0.0 B:-273.1 /0.0
I set S2 to e2temp and now S1 jumps to 92C
if I return S2 to e1temp, S1 returns to 26C:M308 S2 P"e1temp" Y"thermistor" T100000 B3950 M105 T0:26.4 /0.0 T1:-273.1 /0.0 B:-273.1 /0.0
/me confused
/me need helpconfig.g
G90 M83 M550 P"xxx" M551 P"xxx" M552 P0.0.0.0 S1 M586 P0 S1 M586 P1 S0 M586 P2 S0 ; Drives M569 P0 S1 M569 P1 S1 M569 P2 S0 M569 P3 S1 M569 P4 S1 M584 X0 Y1 Z2 E3:4 M350 X16 Y16 Z16 E16:16 I1 M92 X80.00 Y80.00 Z400.00 E4074.37:4074.37 M566 X900.00 Y900.00 Z120.00 E150.00:150.00 M203 X6000.00 Y6000.00 Z1200.00 E1200.00:1200.00 M201 X500.00 Y500.00 Z100.00 E250.00:250.00 M906 X1000 Y1000 Z1000 E800:800 I30 M84 S30 ; Axis Limits M208 X0 Y0 Z0 S1 M208 X220 Y220 Z300 S0 ; Endstops M574 X1 S1 P"xstop" M574 Y1 S1 P"ystop" M574 Z1 S1 P"zstop" ; Z-Probe M558 P9 C"zprobe.in" H5 F120 T3000 M950 S0 C"exp.heater3" G31 P500 X10 Y20 Z2.5 M557 X15:6 Y15:195 S20 ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 M308 S1 P"e0temp" Y"thermistor" T100000 B3950 M308 S2 P"e1temp" Y"thermistor" T100000 B3950 M950 H0 C"bedheat" T0 Q100 M950 H1 C"e0heat" T1 M950 H1 C"e1heat" T2 ; Fans - TBD M106 P0 S0.65 H-1 M106 P1 S0.65 H-1 M106 P2 S0.85 H1:2 T100 ; Tools - TBD M563 P0 D0 H1 F0 G10 P0 X0 Y0 Z0 G10 P0 R0 S0 M563 P1 D1 H2 F1 G10 P1 X0 Y0 Z0 G10 P1 R0 S0
looks like I found the problem ... the
M950 H1 C"e0heat" T1 M950 H2 C"e1heat" T2
both were H1 but I still think this looks like a bug... it's stated in documentation that for 3.x firmware sensors and heaters are separate and this does not look that separate
... anyhow, yellow duck solved the problem
