Usign endstop on duex for corexy
Hello guys,
i today setup up my duet with duex. And i connected X and Y motor to duex board to E2 and E3 driver.
Can i use E2 and E3 endstop instead of X and Y endstop. I want to use filament laser sensor on Duet.
Because i read some where on the web that only on Duet board can be connected.Here is code so far:
M569 P5 S0 ; physical drive 5 goes forwards
M569 P6 S0 ; physical drive 6 goes forwards
M569 P7 S0 ; physical drive 7 goes backwards
M569 P8 S0 ; physical drive 8 goes backwards
M569 P9 S0 ; physical drive 9 goes backwards
M584 X6 Y5 Z7:8:9 E3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X430 Y368 Z500 S0 ; set axis maxima; Endstops
M574 X1 Y1 S1 ; set active low and disabled endstopsMatej
Should be possible to remap in RRF3: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M574
Not sure if it's possible with RRF2.x
So ehat i need to change?
@matej1006 said in Usign endstop on duex for corexy:
no as you said
https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_LaserVersion
you can not use the endstops on the duex.you can use e0 or e1
@Veti What about x and y end stops on duet i would like to use 4 sensor for my 4 tools
use e0, e1, z and CONN_LCD
edit: there are actually 2 endstops on CONN_LCD that you can use. see
https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
Thanks
