Using Dyze design Pulsar extruder with Duet wifi
I m not using it for 3d printing, it will be stationary .
How can i trick the system into keep on extruding.
Send a succession of G1 Exxx commands?
In the config.g file ?
M120
M83
G1 E100 F3600
M121I get an error saying warning motor phase A may be disconnected reported by drivers 1
motor phase B may be disconnected reported by drivers 1
I get the same error when I press extrude on the browser console.
Do you have a motor defined but not connected in your config, what is connected to driver 1?
I changed the wiring up so I am not getting that error
"warning motor phase A may be disconnected reported by drivers 1
motor phase B may be disconnected reported by drivers 1"However it is still not extruding (stepper motor not moving) when I push the extrude button on web interface or by sending Gcode command:- G1 E100 F1800
Here's my complete Gcode on config.g file:-
; generated by RepRapFirmware Configuration Tool v2.0.5 on Mon Oct 21 2019 17:49:30 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M551 P"fcmf" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M584 E0:1 ; set drive mapping
M350 E1:1 I1 ; configure microstepping with interpolation
M92 E420.00:420.00 ; set steps per mm
M566 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 E250.00:250.00 ; set accelerations (mm/s^2)
M906 E280:280 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M140 H-1 ; no bed heater
M950 H1 C"out1" T1 ; create heater 1
M950 H2 C"out2" T2 ; create heater 2
M950 H3 C"out3" T3 ; create heater 3
M950 H4 C"out4" T4 ; create heater 4
M950 H5 C"out5" T5 ; create heater 5
M950 H6 C"out6" T6 ; create heater 6M305 P1 T4606017 B5848 C5.548428e-8 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S480 ; set temperature limit for heater 0 to 480C
M305 P2 T4606017 B5848 C5.548428e-8 R4700 ; set thermistor + ADC parameters for heater 2
M143 H2 S480 ; set temperature limit for heater 0 to 480C
M305 P3,4,5,6 T4606017 B5848 C5.548428e-8 R4700 ; set thermistor + ADC parameters for heater 3
M143 H3:4:5:6 S480 ; set temperature limit for heater 3-6 to 480CM307 H1 A39.2 C46.4 D21.7 V24.0 B0.5 ; Auto tune model for Heater 1
M307 H2 A188.6 C241.0 D9.6 V24.0 B0.5 ; Auto tune model for heater 2; Tools
M563 P0 D1 H1:2 S"PulsarBeta" ; define tool 0
G10 P0 R210.0:220.0 S230.0:240.0 ; set initial tool 220 active and standby temperatures to 230C
M116 H1:2 S2 ; wait for heater 1 and 2 to reach temperatures within +,- 2 degrees
M203 X6000 Y6000 Z300 E10000M200 D2.85 ; set all extruder filament diameters to 2.85mm
M120
M83
G1 E100 F3600
M121M563 P1 H3:4:5:6 S"DIE" ; define tool 1
G10 P1 R210.0:210.0:210.0:210.0 S240.0:240.0:240.0:240.0 ;set initial tool 210 active and standby temperatures to 240C; Custom settings are not defined
From your config.g file:
M116 H1:2 S2 ; wait for heater 1 and 2 to reach temperatures within +,- 2 degreesYou haven't selected a tool, so the M116 command won't wait. You need to select Tool 0 before you extrude. However, we don't expect any movement or heating to be done in config.g. So I suggest you put the G10 temperature setting commands, the T0 or other tool selection command, and the M116 command in a separate macro file.
This post is deleted!
