RRF3 limit max heater PWM?
need to run a 12V heater on a 24V rail "for a few weeks" ... dual extruder setup, one heater is 24V other is 12V, is there a way to setup one heater to never use more than 50% pwm? I don't see that M950 have this option ... not a big issue if not possible but would skip adding external hw if I can solve it in fw
@smece I will assume here that you know it is highly discouraged to use 12V heaters with 24V power supply. Also you would need to limit it to 25% and not just 50. PWM limit is not applied via
M950
but viaM307 Snnn
parameter. In your case that would beM307 S0.25
. But again: not a good idea - but I think you know that already. -
yes, not a good idea, I agree 100% but I'm waiting for new ones to arrive and I wanna do some simple tests where this would be acceptable ... 50% will do these are low power heaters with 50% pwm of 24V they will be just fine
@smece said in RRF3 limit max heater PWM?:
if you double the voltage you quadriple the power.
so you would be running a 30W heater at 120W at full power.
that is why @wilriker said 25% -
@Veti said in RRF3 limit max heater PWM?:
And consequently a 12V 30W heater will be running at around 60W with 24V 50% PWM.
This is possible using the S parameter of the M307 command. But as others have noted, it is also unsafe. The printer should most definitely not be left unattended.
it's crappy 18W heater on the huge piece of alu block so no worries, it's plenty safe, and everything is not even in beta stage so nothing is unattended and I have a finger on the power non-stop ... it's just that I missed M307 as there's "update" on the rrf3 page not mentioning S so I didn't bother to check main gcode doc to read the rest of the parameters that didn't change so I wrote here ... as for ohm's law It's been 30years since I learned it but those things you don't forget that easy
actually 12W, even worse in theory it would behave like ~50W 24V but not sure how good the inside of it is (I seen some where there's huge gap between wires and outter metal, no sand/ceramic/fire-cement between thermal wire and casing) and in case is not good it can burn out... so I wanna control the max pwm output for just in case .. 50% will do the trick (mind, I'll start with 10% to test if it works at all taking into account the firmware is beta too)
