SOLVED M558 R parameter changed?
Unless I've lost my mind (which is entirely possible), the R parameter used to create a delay between the finish of an XY move and the probe action. This was to allow any XY movement to settle out before probing. When running
G30 Pn
as part of bed.g this still seems to be the case. When homing though, this seems to affect the dive timing...; homez.g G91 ; Move bed away from nozzle G1 H1 Z2 F200 G30 ; Pause "R" seconds. ; Move Z until probe is triggered. ; Backs off dive height, then pauses "R" seconds again. ; Dives to trigger probe. ; Move to Z0 G90 G1 Z0
It appears that "R" is being used to let "Z" settle now?
Forgot to add relevant config...
; Z-Probe Precision Piezo Orion M574 Z1 S2 ; Probe Probe Dive Travel Probe ; Pin Type Invert Settle Speed Height Speed Attempts Tolerance M558 C"io8.in" P8 I1 R1 F300 H5.0 T10000 A4 S0.05 ; Trigger Trigger ; Value Offset Height G31 P300 X0 Y0 Z-0.10
The R parameter is to allow all motion to settle. A G30 move with a P parameter may involve movement in any or all of X, Y and Z. For a Smart Effector and some types of Piezo sensor, the sudden Z deceleration could cause false triggering.
However, the code doesn't check whether there has been recent moment or deployment, it always inserts the delay.
For a simple G30 command, the delay should occur between completion of the previous command and the start of the dive. If the probe needs to be deployed, the delay should occur after deployment.
@dc42 said in M558 R parameter changed?:
OK, I don't remember it doing that before. Even if there are no other movement commands in homez.g or even when
G30
is run from the CodeConsole, it's pausing. The reason I noticed it was because I used to have aG1 H1 Z-450 F1200
before theG30
to get the bed to the nozzle quickly and what was happening was the bed would move to the nozzle, trigger the probe, then stay there with the bed in contact with the nozzle for "R" seconds beforeG30
started the backoff. This was definitely new behavior with the recent endstop changes. I always thought that the "R" parameter was supposed to allow XY to settle, not Z.
OK, I guess this is a change but not a bug.
Are you sure the behaviour has changed? There has been no intentional change.
Oh yes. It was very noticeable but I'll rebuild RRF without the recent commits and test again.
Well, I can't find a combination of commits across projects that will compile so don't worry about it. It was a minor nit and I can work around it easily.
