SOLVED Z homing issues
I have a CoreXY with a 5v npn probe. The probe triggers when metal is present but it doesn't stop moving. Also in the config tool, it asks about trigger value. Is that volts ohms milliamps? Please help.
post the config.
for trigger value the default should be ok, as npn is normally either 0 or 1000.
; generated by RepRapFirmware Configuration Tool v2.1.2 on Tue Nov 05 2019 07:09:30 GMT-0500 (Eastern Standard Time); General preferences
M550 P"450 Hypercube" ; set printer nameM667 S1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
M906 X925 Y925 Z925 E925 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X450 Y450 Z500 S0 ; set axis maxima
@tham40 said in Z homing issues:
there is no probe configuration in your config.
you need something like this
M574 Z1 S2 ; set endstops controlled by probe
M558 P5 H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger heightand the corresponding homing files like for example
homeall.g
G91 ; relative positioning
G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 H2 X15 Y15 F6000 ; go to first bed probe point and home Z
Now I'm getting an error of Z probe already triggered at start of probing move
Add I1 parameter to M558 command, but better start with reading these:
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe and
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
I had read those a couple times . Adding the I1 worked. Thanks guys.
