    Duet2Ethernet startup problem
    • MatthiasSchusterundefined
      MatthiasSchuster
      Have got a problem with my Duet2Ethernet.
      It was running smoothly for about 1 week.
      Now it's not booting anymore and the display isn't working aswell.
      The supply voltage LED is lit up, but the 5V and 3.3V LEDs are missing.
      Thanks for help.
        Does the small square chip labelled U3 close to the 5V_INT_EN jumper look damaged?
          MatthiasSchuster
          The chip does not seem damaged to me.
            Have you checked the 7.5A fuse?
