Wifi problems on Mac
@Jaime M588 S"ssid" I think is the correct format?
@Dougal1957
M587 S"Red Wi-FI de Jaime Capllonch"
this supouse to be correct. -
@Jaime I think so but it is a longtime since I had to do it!
Send
M588 S"*"
to clear the entire current list.Then send
M587 S"Red Wi-FI de Jaime Capllonch" P"password"
Then send
M587
by itself to see if it was added to the list correctly.If the letter case wasn't preserved, you can use a macro on the SD card to add it rather than send it over USB console.
@Phaedrux
Awesome!! thats great WORKS!!
thanks a lot. -
@Jaime none of the ones that were stored were correct; SSID is case-sensitive, and/or hyphen was missing!
@droftarts thanks for your help !!
@Jaime hi, just to be sure, wich is the latest firmware?
@Jaime You're on FIRMWARE_VERSION: 2.02(RTOS), from 2018-12-24. Latest is 2.05.1, and has many fixes. Here: https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
You could update to RepRapFirmware 3, which is the version that will be receiving the development from now on, but if you don't need the features, stick to RRF 2.
you'll find the reprap releases here https://github.com/dc42/RepRapFirmware/releases
