Duet ethernet running latest firmware motors not moving at all
@ageis said in Duet ethernet running latest firmware motors not moving at all:
G31 P500 X230 Y9 Z2.5 ; set Z probe trigger value, offset and trigger height
your x offset is bigger than the probing area. it cant be 23cm away. i dont know what this would do.
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
your z steps seem way off. it should be 400.
please check if there is continuity between the trinamic chip output and the pins.
https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2660_datasheet.pdf
using OA1, OA2 and OB1, OB2 pins.also are you sure its a genuine board and not a chinese clone? if its a chinese clone they could have used bad chips.
Thats what I mean't by tested from the driver to motor and back again. Definately genuine from ooznest
M203 X360000.00 Y360000.00 Z10800.00 E72000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y20.00 Z250.00 E250.00 ; set accelerations (mm/s^2)also your y acceleration is way to low and your max speed way to high
@Veti said in Duet ethernet running latest firmware motors not moving at all:
Low acceleration is OK, but the unreasonably high speeds in M203 could be the problem. Try reducing them from 360000 to 6000.
Thanks alot david.
As soon as I used the values hard coded into prusa original firmware it started moving.
Good damn it always a pebkac
