Unsolved Prusa upgraded to duet, weird extrusion
The motor shaft is straight, the gear is straight. Motor switch didn't help. All of them pulse. I will try reducing my microsteps to 8.. Maybe somebody knows about a TMC parameter called "Velocity"? I remember there's some register adjustments but I can't find it at the moment..
@Phaedrux It does, in fact, all the 0.9 degree motors I bought sound like that. Even without load.. I suspect that I need to adjust something in the drivers themselves. I used 1.8 degree steppers, now I got 0.9 degree ones.
What is the power supply?
@Phaedrux Whatever came with Prusa MK2S originally.. 12V and I guess 20A? Maybe 15A, not sure.
Can you post the results of an M122 command after doing a print?
Using 8x microstepping probably won't do much other than make the motor noisier.
I use the same E3D motor for my Titan aero without such a pattern.
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3S4-6JKDD-3S06R-KBQ3D Used output buffers: 3 of 24 (7 max) === RTOS === Static ram: 25680 Dynamic ram: 92824 of which 0 recycled Exception stack ram used: 436 Never used ram: 12132 Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,1664) IDLE(ready,200) Owned mutexes: === Platform === Last reset 00:06:26 ago, cause: software Last software reset time unknown, reason: User, spinning module GCodes, available RAM 12132 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 10.7ms, max retries 0 MCU temperature: min 41.3, current 41.7, max 42.4 Supply voltage: min 12.1, current 13.0, max 13.5, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: ok, SG min/max 0/384 Driver 1: standstill, SG min/max 0/400 Driver 2: ok, SG min/max not available Driver 3: ok, SG min/max 0/463 Driver 4: ok, SG min/max not available Date/time: 2019-12-18 23:02:44 Cache data hit count 1365610563 Slowest loop: 117.87ms; fastest: 0.06ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 157, MinFreeDm: 146, MaxWait: 135474ms Bed compensation in use: mesh, comp offset 0.007 === DDARing === Scheduled moves: 357, completed moves: 353, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.7 Heater 1 is on, I-accum = 0.6 === GCodes === Segments left: 1 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is doing "G1 Z2.198 X134.775 Y95.225 E0.63527" in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 83.15ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 80:7d:3a:15:2c:b0 WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25696 WiFi IP address 192.168.1.253 WiFi signal strength -44dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 === Filament sensors === Extruder 0 sensor: ok
I am doing a print right now, so here you go.
FYI the PSU IS overvolted to 12.5V.
@Phaedrux said in Prusa upgraded to duet, weird extrusion:
Yup, didn't do anything.
This is after a full print:
12/18/2019, 11:58:36 PM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3S4-6JKDD-3S06R-KBQ3D Used output buffers: 1 of 24 (7 max) === RTOS === Static ram: 25680 Dynamic ram: 92824 of which 0 recycled Exception stack ram used: 460 Never used ram: 12108 Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,1564) IDLE(ready,200) Owned mutexes: === Platform === Last reset 00:28:34 ago, cause: software Last software reset at 2019-12-18 23:29, reason: User, spinning module GCodes, available RAM 12124 bytes (slot 1) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 39.2ms, max retries 0 MCU temperature: min 42.1, current 43.4, max 44.0 Supply voltage: min 11.6, current 13.0, max 13.6, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max 0/1023 Driver 1: standstill, SG min/max 0/1023 Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max 0/1023 Driver 4: standstill, SG min/max not available Date/time: 2019-12-18 23:58:33 Cache data hit count 4294967295 Slowest loop: 156.87ms; fastest: 0.06ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 160, MinFreeDm: 114, MaxWait: 68278ms Bed compensation in use: mesh, comp offset 0.005 === DDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.5 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 157.02ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 80:7d:3a:15:2c:b0 WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25936 WiFi IP address 192.168.1.253 WiFi signal strength -41dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 === Filament sensors === Extruder 0 sensor: ok 12/18/2019, 11:56:54 PM Finished printing file 0:/gcodes/Ripple_test_0.2mm_PET__19m.gcode, print time was 0h 26m
The print:
The config:
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.3 on Sat Nov 30 2019 21:16:45 GMT+0200 (Eastern European Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Prusa Bear MK2.5" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards M584 X0 Y1 Z2:4 E3 ; set drive mapping M671 X-36.0:290.0 Y110:110 S1 ; Set the Z motor relative locations correction 1mm M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X200.00 Y200.00 Z400.00 E276 ; set steps per mm M566 X600.00 Y600.00 Z12.00 E150.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z360.00 E7200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z200.00 E10000.00 ; set accelerations (mm/s^2) M906 X1200 Y1200 Z600 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y-4 Z0 S1 ; set axis minima M208 X250 Y210 Z210 S0 ; set axis maxima ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z1 S2 ; set endstops controlled by probe ; Z-Probe M558 P1 H0.85 F600 T12000 ;A3 S-0.03 ; set Z probe type to switch and the dive height + speeds G31 P500 X23 Y5 Z0.625 ; set Z probe trigger value, offset(original 0.875) and trigger height M557 X24:228 Y6:210 S50 ; define mesh grid ; Filament Sensor M591 D0 P2 C3 S1 ; Heaters M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous T0 ; select first tool
Maybe my acceleration/jerk values are bad now? This is the first time I do such a conversion. I switched from 1.8 degree to 0.9 degree on X/Y and E. The config is still for 1.8 degree motors except for the steps and currents. Z motors are still original.
Interesting observation: the movement seemed to pause A LOT. Especially between infill/perimeters and z-lifts/retractions. Felt very sluggish.
@Murloc992 said in Prusa upgraded to duet, weird extrusion:
M201 X1000.00 Y1000.00 Z200.00 E10000.00 ; set accelerations (mm/s^2)Yes your Z and E axis settings are very conservative. this will make for slow retractions and layer changes / zhops.
The low XY jerk and acceleration don't seem to match up with the large amount of ringing you are seeing. Are your belts a little loose?
Here's what I use on my i3
M566 X800 Y800 Z60 E3000 P1 ; Set maximum instantaneous speed changes (mm/min) M203 X12000 Y12000 Z900 E6000 ; Set maximum speeds (mm/min) M201 X6000 Y6000 Z200 E5000 ; Set accelerations (mm/s^2) M204 P600 T3000 ; Set accelerations (mm/s^2) for print and travel moves
The pauses you speak of are most likely due to the jerk setting you have for your z-axis and extruder. If you are using pressure advance I would change the extruder instantaneous speed change (jerk) to something around 2000 and the Z somewhere in the 150-300 range.
I will try your settings. My belts are not loose, just the right tension, printer moves more smoothly and silently with these motors I put on. Hopefully it's just a setting issue.
I will take a video of it printing in the evening.
No other variables except for the motors have changed.
So I used your settings, prints look identical, just that it printed WAY faster. Weird..
I just noticed that my X idler might be bigger than Y one.. I will investigate shortly..
Nope, seems identical. I am out of what I can do. Every axis seems to move extremely smoothly and fast. The frame is as rigid as it gets..
@Murloc992 if you are still seeing the weird pulsing with @Phaedrux 's config then it might be worth swapping that motor with one of the other ones you bought to confirm that the problem is not with the motor.
Another bit of elimination is to try using E1 for the extruder to rule out some weird failure mode of the driver (highly unlikely but you never know). You can use M584 to switch between E0 and E1
@T3P3Tony I already tried switching the motor, same pulsing. I haven't tried switching the driver yet, but I use dual Z, can I set Z as E0?
@Murloc992 yes remap as you like. Also another option for this test you can connect two Z in series to the Z motor connector
@T3P3Tony I am printing another single wall cube and notice something new with new acceleration/jerk settings. I will post soon. I still hear the pulsing though, but it looks a bit different than before.
X Axis:
Y Axis:
As you can see, increasing the settings(speeds, acceleration) made the pattern reversed(of all the things) and more intense.
@Murloc992 what about rotation by 45degrees?
Let me try.
