    termistors
    414
    • minimaxerundefined
      minimaxer
      Hello I have the Duetwifi built into the UM2. Only the termistors are plugged into the borad - now both indicate wrong temperatures.
      • Dougal1957undefined
        Dougal1957
        post your config.g!
        minimaxerundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti
          what thermistors does the um2 have?
          Dougal1957undefined minimaxerundefined 2 Replies Last reply Reply Quote 0
            Dougal1957 @Veti
            @Veti said in termistors:
            don't UM2's use Thermocouples or have I remembered incorrectly (Highly possible)
              minimaxer @Dougal1957
              @Dougal1957
              the config.g
              ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sat Dec 28 2019 00:04:16 GMT+0100 (CET)
              M550 P"My Printer" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M350 X256 Y256 Z256 E256 I0 ; configure microstepping without interpolation
              M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X220 Y220 Z200 S0 ; set axis maxima
              M574 X1 Y1 Z1 S1 ; set active high endstops
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:215 Y15:195 S20 ; define mesh grid
              M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
              M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
              M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                minimaxer @Veti
                @Veti what thermistors does the um2 have?
                Is a UM2 +, the termistors have previously worked properly.
                  minimaxer
                  I have to make every connector for the Duet, but before the termistors do not work - it has no purpose.
                    minimaxer
                    Termistor for hotend and heating bed
                    • DocTruckerundefined
                      DocTrucker
                      What is the resistance of the sensor when disconnected from the board?
                      What values have you found for the sensors?
                      • aidarundefined
                        aidar
                        From UM2 firmware, it seems they use PT100 instead of regular thermistors, both hotend and bed.
                          minimaxer @DocTrucker
                          @DocTrucker
                          112k
                            dc42 administrators @minimaxer
                            @minimaxer said in termistors:
                            @DocTrucker
                            112k
                            Are you sure you mean 112K, not 112 ohms?
                              minimaxer
                              oh sorry - 112 ohm
                                oh sorry - 112 ohm
                                In that case, @aidar is right, they are PT100 sensors, not thermistors. To use them with Duet you need the PT100 daughter board. One board handles two PT100 sensors.
                                  minimaxer
                                  Ok, I read it, the UM2 + has PT100 sensors and I need an extra board -: ((
                                  DocTruckerundefined 1 Reply Last reply Reply Quote 0
                                    DocTrucker @minimaxer
                                    @minimaxer wasn't able to get back online last night but suspected PT100 as I had the same issue when converting an Up Plus 2 for someone an age ago.
                                    Ok extra cost but the boards mount on Duets (post 0.6 or 0.8.5) with no extra hardware. PT100 are better sensors on many measures, but rely on a well shielded system. That said, if you are converting a machine like the ultimaker then shielding issues are likely already sorted, unless it is broken accidentally in the conversion.
                                    Just keep an eye out for impossible heat changes on the temp plot. In other words if there are sudden changes of 5-10C or more in reported temp in an instant then you have wiring or noise issues.
