    DuetWiFi RRF 3 + filament magnetic sensor + water flow sensor
    • c310undefined
      c310
      Hi! I am planning some upgrade: install Duet magnetic sensor and water flow pulse sensor (for water cooling). Water flow sensor link
      I read documentation and understood that water flow sensor can be used as pulse by M591.
      Questions: is it possible to fit both sensors on duet board ? Also, i have emergency stop button occupying e1 pins.
      thanks!
      c310undefined 1 Reply Last reply Reply Quote 0
      • c310undefined
        c310 @c310
        @dc42 please advise
          M591 is intended for measuring the amount of filament drawn by the extruder drive, so that RRF can correlate it with the commanded extrusion. So I don't see how you could use it with a flow sensor. Also, each extruder drive can only have one filament monitor.
          The flow sensor link you provided requires a login, so I can't see the details. But if it provides 5V output pulses then you could use a Greinacher voltage doubler (two Schottky diodes and two capacitors) to generate a steady signal of about 3.5V as long as pulses are occurring. That could be fed to an input to activate a trigger using M581.
          • c310undefined
            c310 @dc42
            @dc42 said in DuetWiFi RRF 3 + filament magnetic sensor + water flow sensor:
            thank you!
