    Could StallGuard be used to detect _lack_ of load?
    379
    • janjohundefined
      janjoh
      Could StallGuard of the TMC2660 on DuetWifi somehow be used to detect a LACK of load? Reason for asking is a recent experience with an almost broken drive belt on a Delta machine that normally prints quite fast.
      Bu i guess the answer is "No, StallGuard can only detect excessive load"?
      • A Former User?
        A Former User
        What it does is measure what trinamic refers to as the load angle; so "yes" its possible to determine-(ish) the amount of load.
        But if its possible with current RRF I couldn't tell you; but the same caveats applies to this as it does with sensorless homing. Its not 100% reliable, especially at high and low speeds, so ultimately not sure if its useful in your application.
        janjohundefined 1 Reply Last reply Reply Quote 0
        • janjohundefined
          janjoh @A Former User
          @bearer said in Could StallGuard be used to detect _lack_ of load?:
          That pretty much sums up what i thought as well.. And i realize that apart from a sensing idler or photo-gate, I cant see a good way to detect a broken drive belt.
          Ok, apart from a multiaxis accelerometer on the effector that compares the measured motion to the expected motion. Hmmm, could Duet3 and its CAN bus...
          littlehobbyshopundefined 1 Reply Last reply Reply Quote 0
          • A Former User?
            A Former User
            Without knowing much of your mounting, a strain gauge could be a solution if you can mount it where it matters. HX711 modules to interface strain gauges are cheap as chips.
            • littlehobbyshopundefined
              littlehobbyshop @janjoh
              @janjoh perhaps one of those wheeled micro switches against the tensioned belt. Would release once the belt broke and lost tension and can easily be wired into a trigger. Quite simple if it could be applied.
              BLV MGN Cube w/Hemera, K8200, Sunlu S8
              janjohundefined 1 Reply Last reply Reply Quote 1
              • Danalundefined
                Danal
                I would think this would be the perfect application for an optical endstop, assuming its slot is wide enough.
                janjohundefined 1 Reply Last reply Reply Quote 2
                • janjohundefined
                  janjoh @Danal
                  @Danal said in Could StallGuard be used to detect _lack_ of load?:
                  I see one potential problem. You seem to be assuming that the belt would fall out of the slot upon failure. I can see many scenarios where that would not happen. Or, do you see a way to actually detect the teeth passing through an optical sensor?
                  I think the least impractical ways would be a a microswitch as previously mentioned, or to detect rotation of the idlers.
                  • janjohundefined
                    janjoh @littlehobbyshop
                    @littlehobbyshop said in Could StallGuard be used to detect _lack_ of load?:
                    Yeah, that is probably the most simple solution, especially since it would be so easy to wire three NC in serial.
                    What bugs me about my failure is that I didnt get any advance warning in form of fraying of belt that i had seen.. and lets face it, we all watch most of our first layers, right?
                    • Danalundefined
                      Danal
                      Good point, the belt may not fall out of an optical. But that raises the same q for a microswitch: Where is the microswitch positioned that the belt is guaranteed to go slack?
                        dc42 administrators @janjoh
                        @janjoh said in Could StallGuard be used to detect _lack_ of load?:
                        To answer the original question, in theory StallGuard could be used to detect lack of load. But it would only be possible while executing a move for which the load is significant - for example, accelerating a heavy print head, such that the load due to the inertia of the print head is greater than the load due to rotor inertial if the motor.
