    M204 commands - are they queued like movement commands?
    • garyd9undefined
      garyd9
      I'm trying to determine if M204 commands are being handled by the duet RRF2 (or RRF3) firmware before G1 movements that occur AFTER the M204 commands.
      As a completely fictional example, consider the following:
      M204 P1000 ; fast accel
      ... ; 100 or so movements with extrusions
      M204 P300 ; slow down printing accel
      G1 X0 Y10 E1 ; what accel is this running at?
      What acceleration is used for the last G1 command? 1000mm/sec/sec or 300mm/sec/sec?
      The reason I'm asking is that I've playing with cura's acceleration control options, and I'd send M204 commands (with no parameters) via the console while watching a print. From that, it appears that the G1 movements/extrusions are queued, but that the M204 commands somehow skip the queue and take effect immediately. The end result is that embedding M204 commands to change accel for different parts of the print is somewhat useless, as the commands take effect too early.
      "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
        You are quite right, M204 commands are not being synchronised with movement commands. I will fix that in RRF 3.1.
        dc42undefined 1 Reply Last reply Reply Quote 1
          dc42 administrators @dc42
          @dc42 said in M204 commands - are they queued like movement commands?:
          EDIT: thinking about it, I think that answer may be wrong. The acceleration is computed when the move is put in the movement queue, which means M204 commands should take effect exactly when they should, i.e. with the next movement command in the file.
          garyd9undefined 1 Reply Last reply Reply Quote 0
          • garyd9undefined
            garyd9 @dc42
            Okay, that would explain why M204 returns a "new" accel before the movement has physically occured (but is already queued.) Thank you.
