Using PL08-N probe getting bad command r0.2
  • homeall.g This is a new setup on corexy printer (voron)
    Been weeding out problems as I go, been slow but productive till this.
    Message response is Bad command r0.2 when I activate z_probe_ macro.
    [0_1581953284105_config](Uploading 100%)
    homeall.g
    activate_z_probe.g
    go_to_bed_center.g
    Firmware Electronics: Duet WiFi 1.02 or later + DueX5
    Firmware Version: 2.05.1 (2020-02-09b1)
    WiFi Server Version: 1.23
    Web Interface Version: 1.22.6
    Going to use probe for homez is the plan, need to figure it out also.
    Any help or guidance is appreciated.
    CarlJ
    Your file activate_z_probe.g comprises 4 good lines, then 57 blank lines, then a final line that reads "r0.2". That final line provokes the error message.
  • Very good, guess need to scroll down alot to see it.
    Fixed that.
    Now to proceed to next hurdle. Usually I find what I need looking thru the posts. So I don't make many requests.
    It's been a learning experience.
    Thank You
