    2 independent Z lead screws
    • mathew.u
      mathew.u last edited by mathew.u
      Trying to configure my BL touch to auto adjust the Z axis using two lead screws. I found the code for bed.g
      G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      Can I insert this in the bed.g to execute then do a mesh as well?
      how can I execute through the web interface to just self adjust the Z level.
      Here is my config.g file
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Mar 07 2020 12:38:22 GMT-0800 (Pacific Standard Time)
      M550 P"Big-box" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P3 S0 ; physical drive 3 goes backwards
      M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
      M671 X-20:580 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X0:560 Y0:300 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
      M92 X80.00 Y80.00 Z400.00 E409.00 ; set steps per mm
      M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1800 E1300 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z-1.4 S1 ; set axis minima
      M208 X560 Y300 Z560 S0 ; set axis maxima
      M574 X1 Y1 S1 ; set active high endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X42.15 Y-52.36 Z0.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:560 Y50:195 S20 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S285 ; set temperature limit for heater 1 to 285C
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      and this is the error I'm receiving when I try to home the z axis
      Warning: motor phase A may be disconnected reported by driver(s) 2
      Warning: motor phase B may be disconnected reported by driver(s) 2
      Originally I just ran both Z motors via the series connectors, do i need to have those jumpers plugged back in? If so I will have to make some so what connectors need connected?
        Phaedrux Moderator @mathew.u last edited by Phaedrux
        @mathew-u said in 2 independent Z lead screws:
        Yes.
        G32 calls bed.g
        Yes you will need to reinstall the jumpers now that you're only using one of the connectors. If you lost the original jumpers you could make up a dummy plug with wire to do the same thing. That would get rid of the error. It's literally telling you that a motor it expected to be connected is not connected, which is true.
        • mathew.u
          Great got it all working but now when I try to auto compensate I get these errors
          2:47:18 PM Error: Compensation or calibration cancelled due to probing errors
          2:47:14 PM G32
          Error: Z probe was not triggered during probing move
          and
          2:49:11 PMG32
          Error: Some computed corrections exceed configured limit of 0.50mm: 0.630 -5.616
            You may need to get them close manually first. One side looks to be several mm out and you have it limited to a 0.5mm difference. This limit could be raised in your M671 command, but keep in mind that your gantry will need some flex to it otherwise it may bind.
            Try getting it close manually first. Then it should stay relatively close when power is removed and the G32 should be able to correct for it going forward.
            • mathew.u
              Got it, problem solved!
              In the config.g in the line
              Does the Z0.5 represent the offset at which the printer will use to start printing? At the moment I can not get prints to start very well because I am having a hard time setting the Z offset but once I start the file I just use the baby offset tool to change the Z every print.
                G31 Z is the trigger height of the z probe. You must calibrate this.
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s231
