    Duet Maestro constantly disconnecting from ethernet
    • pralonam
      pralonam last edited by
      Hi. I feel like I'm going insane here, since I swear this only got this bad when I started using Duet Web Control 2.
      I am constantly getting disconnected from the DWC. As in, every 2 minutes. Then I need to refresh my page and re-enter my password to use the DWC until the next 2 minutes pass, and I'm booted again.
      I get no packet loss pinging the static IP I've assigned it to (to prevent IP clash). I've attached my M122 output in case it helps. Please help me figure this out, I'm pulling hair out getting kicked out of my web control every few minutes.
      Board: Duet Maestro 1.0
      Firmware: RepRapFirmware for Duet 2 Maestro 3.0 (2020-01-03b3)
      Duet Web Control 2.0.7
      m122
      RepRapFirmware for Duet 2 Maestro version 3.0 running on Duet Maestro 1.0
      Board ID: redacted
      Used output buffers: 3 of 24 (15 max)
      Static ram: 24484
      Dynamic ram: 87040 of which 0 recycled
      Exception stack ram used: 196
      Never used ram: 19352
      Tasks: NETWORK(ready,912) HEAT(blocked,1360) MAIN(running,3840) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:02:48 ago, cause: power up
      Last software reset at 2020-03-13 22:13, reason: User, spinning module GCodes, available RAM 19176 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      SD card 0 detected, interface speed: 15.0MBytes/sec
      SD card longest block write time: 3.0ms, max retries 0
      MCU temperature: min 35.5, current 36.3, max 37.0
      Supply voltage: min 24.3, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, read errors 0, write errors 0, ifcount 6, reads 6273, timeouts 0
      Driver 1: standstill, read errors 0, write errors 0, ifcount 6, reads 6273, timeouts 0
      Driver 2: standstill, read errors 0, write errors 0, ifcount 6, reads 6273, timeouts 0
      Driver 3: standstill, read errors 0, write errors 0, ifcount 6, reads 6273, timeouts 0
      Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 6273, timeouts 0
      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 6273
      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 6273
      Date/time: 2020-03-13 22:34:29
      Slowest loop: 6.70ms; fastest: 0.09ms
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 109.63ms; fastest: 0.04ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User @pralonam last edited by
        @pralonam said in Duet Maestro constantly disconnecting from ethernet:
        is that always about the same time as how long it runs? could imply a power issue
        pralonam 1 Reply Last reply Reply Quote 0
          Can you try the latest 3.1 RC?
          • pralonam
            I've upgraded to RepRapFirmware for Duet 2 Maestro version 3.01-RC3 running on Duet Maestro 1.0. Unfortunately, I still disconnect at a rate where I'm unable to even upload a 6mb gcode file to my board without a disconnect in between.
            • pralonam
              pralonam @Guest last edited by
              @bearer As of 2020-03-26:
              Last reset 237:19:48 ago, cause: software
              Last software reset at 2020-03-16 15:50, reason: User, spinning module GCodes, available RAM 20868 bytes (slot 2)
              So no, I don't believe its a total restart. This also happens during printing with no interruptions to the print.
                Have you tried a different browser yet? Is the tab perhaps going into a low power idle state?
                • pralonam
                  pralonam @Phaedrux last edited by
                  @Phaedrux This occurs on both Firefox on my desktop and Chrome on my Android. Often when the tab is opened.
